Alignment Settings
Old Nov 19, 2009 | 04:22 AM
JSWhaler's Avatar
Default Alignment Settings
Today I'm going to get my car aligned. The setup will be mostly for spirited driving and some auto x. As for tire wear, not too concerned as long as I get 7-8k miles from the rears. I'm currently running KWV3's OEM sized tires ala AP2 (17" 215 front 245 rear) and a saner bar middle setting. My set up thoughts are the following:
Front
Toe: 1/16" out
Camber: -1 to -1.25
Caster: Max 6-6.5
Rear
Toe: 1/8" in
Camber: -2 to -2.25
Thoughts opinions? Am I over looking something? Thanks
Old Nov 19, 2009 | 05:17 AM
Rodney's Avatar
that is a decent starting point, but personally i would run more front camber, max it out if possible.
Old Nov 19, 2009 | 05:23 AM
ZDan's Avatar
Maximize front and rear camber.
Toe settings, those are total, not per side, right? Should be fine.
Personally I go with zero toe in front.
Old Nov 19, 2009 | 05:39 AM
JSWhaler's Avatar
Yes toe settings are total, not per side.
Old Nov 19, 2009 | 07:13 AM
bronxbomber252's Avatar
Id go 0 toe in front, -1.5ish front camber, Otherwise that looks like a great starting point
Black_AP1
Apr 20, 2016 06:37 AM
JSWhaler
Apr 13, 2010 07:53 AM
S2K:-)
Apr 13, 2006 08:31 PM
RazorV3
Nov 14, 2004 08:18 AM
gerryk
Oct 19, 2003 09:46 PM
