Alignments are important
Old Sep 17, 2009 | 12:30 AM
  #31
jyeung528's Avatar
Originally Posted by cuonice,Sep 7 2009, 04:30 PM
I think you're right There are two "easy" ways to control the S's tendency to oversteer on non-staggered tires: a ricey wing or a large front bar, but not both in my experience. Add rear toe to desired taste
I chose the wing route and found the car to be very tame with very little rear toe.
what about adjusting the shocks? softening the rear and stiffening the frong?
Old Sep 17, 2009 | 01:41 AM
  #32
WynnS123's Avatar
Yes that helps too.
Old Sep 17, 2009 | 08:27 AM
  #33
nissanfanatic's Avatar
I could only get about -1.7* of negative camber up front out of one side. The other would go to -1.9 or so, so I equalized them at -1.7 and zeroed toe. The rears are at -2.4 camber with 1/16" gross toe in. What do most get out of the front for negative camber stock? The car definitely seems much better as far as steady state cornering and doesn't seem to oversteer. It does about 1G for cornering via Performancebox on Dunlop Direzza star specs, so it isn't bad. I just expected to get more camber out of the front...(?)
Old Sep 17, 2009 | 10:40 AM
  #34
WynnS123's Avatar
^^ that's about all you're going to get up front if you are at stock height.
RedCelica
Jan 15, 2012 04:49 PM
TrueDrezzer
Mar 23, 2004 04:52 PM
Voodoo_S2K
Nov 28, 2003 12:18 AM
FSures
Mar 19, 2002 03:03 PM
jguerdat
Jan 23, 2002 09:58 AM
