Alignments thoughts for new setup
Old Aug 16, 2010 | 11:26 AM
az3ar's Avatar
Default Alignments thoughts for new setup
Since I have revlaved my KW V3 to Club Sport and got few new suspension parts I am debating what alignment settings I should go with and of course what ride height. I have a basic idea on what to go with but since my setup is different than others thoughts and ideas are always welcome and appreciated.
The car has the following.
2600 pounds with half tank of gas
New hard bushings all around + new alignment bolts
Top ball joints in the front arm controls to add camber
Rear control arms for bump steer and for adding more camber
17 by 9 inch rims on 255 wide tires... I switch between R comps and street depending if I am instructing or running competitive.
Saner front swat bar
Stock rear bar with adjustable end links
No wing
I am looking for more oversteer as I like how it rotates the car. I am thinking:
FRONT: - 3.5 Camber with zero toe and 7.5 caster... I can push for more caster
Rear - 3.0 Camber little toe in
Ride height 1 inch lower than stock with a little reck in the front. That’s 4 inches from the jacking points.
Thanks
Old Aug 16, 2010 | 12:17 PM
TubeDriver's Avatar
You should have plenty of rotation with that setup (or just put your OEM rearbar back on).
I'll see you at SP Friday (I'll be there Sat/Sun too) so we can compare notes.
My setup is similar (KW CS, 17x9, Nitto NT01 255, Comptech Race bar, but I have OEM rear bar and wing).
I have J's balljoints but have not installed them yet.
Old Aug 16, 2010 | 12:34 PM
az3ar's Avatar
I do have the stock bar on, I am planning on keeping it
I will be at BSR this FRI but won’t make SAT SUN with NASA :S
Little too much on my plate these couple weeks and I really don’t feel being under the sun for 3 straight days
Yea we need to hang out and compare; I have invested over 140 hours worth of work on that car and if it does not work perfect this weekend I am just going to push it off the cliff and buy a BMW
Old Aug 17, 2010 | 04:40 AM
az3ar's Avatar
Does anyone have any objection on the front and rear alignment? do you think its over kill for double wishbone setup?
Old Aug 17, 2010 | 06:34 AM
mLeach's Avatar
With that much camber in front I would want less caster. You run the risk of using less of the tire, especially in slow speed tight situations.
Old Aug 17, 2010 | 09:52 AM
az3ar's Avatar
So you think I should go with 3.2 camber and 7.5 caster or (for example) 3.5 camber and 6.5 caster.
should I take camber or caster away? I know 3.5 camber is a lot for double wishbone car and thats why I started this thread.
Some alignment experts say max your caster then max the camber... at the rate I will end up with 8.5 caster
Thanks
mrbond413
May 18, 2014 09:57 AM
maranelloboy05
Mar 31, 2014 09:38 AM
thanasis11
Jan 13, 2013 03:10 AM
dsddcd
Mar 15, 2012 05:35 PM
jack1122
Sep 10, 2005 09:34 AM
