Analyze my setup...
Old Apr 14, 2008 | 03:36 PM
  #81
MADANT15's Avatar
My instructor was Rob Burgoon, the guy with the purple miata. Before him, I was running in the low 2 30s but after his instruction and practice I got down to 2 19.4. There is still a lot more left in the car though, even as it is.
Old Apr 14, 2008 | 03:57 PM
  #82
S2Kretard's Avatar
Originally Posted by krazik,Apr 14 2008, 02:35 PM
FWIW,
I run my hooisers at 32 hot. Tho I'm not about to say i've done a ton of temp testing on it them. Just messing with pressures over the years and I find they behave much better when I treat them (pressure wise) more like slicks.
Is that a street tire? Radial or bias ply? (Aren't the GrandAm hoohoo's bias ply?)
Old Apr 14, 2008 | 03:58 PM
  #83
S2Kretard's Avatar
Billy Johnson was my instructor and I ran a 3:17
Old Apr 14, 2008 | 04:04 PM
  #84
krazik's Avatar
Administrator
The DOT R6. I have to run a DOT tire for ITE.
https://www.hoosiertire.com/specrr.htm#SPOR...A3S04%20&R3S04)
Old Apr 14, 2008 | 04:23 PM
  #85
nsxtasi's Avatar
That's freaking fast, does he take new student?
Old Apr 14, 2008 | 04:31 PM
  #86
Jaku's Avatar
there are too many variations in the case of your car
ride height, shock stroke, shock damping, sway bar stiffness, sway bar binding, roll center, alignment and most importantly driver will all have big effect on the output of a car handling
if you can start out on bone stock S2000 then you will know what the difference of every change
for a reference tho, bone stock S2000 potential is about 2'10s +- 1s depends on weather
and if the driver can not drive some what consistantly close to the limit, the output of a car handling is often not true
that means if the driver is more consistant, any changes on the car is more believable
did u get to drive Sat or Sun?
Old Apr 14, 2008 | 04:45 PM
  #87
nsxtasi's Avatar
Old Apr 14, 2008 | 04:50 PM
  #88
smirfs2k05's Avatar
Originally Posted by mikegarrison,Apr 14 2008, 02:58 PM
There is courage, confidence, and skill. It's great to have all of them, but in my experience having courage and/or confidence without having enough skill to back it up makes for a short track driving career.
If somebody drops 15 seconds in a single day, after getting one session of instruction, then I would call that a very productive session of instruction.
When you run out of skill thats when you wad your car up .. Thats why I'm scared of the track I know I'll push hard but lack of skill/experience will come into play.
Old Apr 14, 2008 | 05:07 PM
  #89
LostMotion's Avatar
Originally Posted by S2Kretard,Apr 13 2008, 04:37 PM
- Pretty sure 30 hot is way too low...
hmm yes comment retracted.
Old Apr 14, 2008 | 05:35 PM
  #90
S2Kretard's Avatar
You drive an STi, just point where you want to go and push the pedal on the right.
Seriously
