Anyone know CR spring rates?
Old Nov 9, 2008 | 06:23 AM
phoQ's Avatar
Default Anyone know CR spring rates?
Just curious, because I want to lower my Club Racer, but do not want to change the spring rate to dramatically. My opinion on the whole thing is that if I keep springs that have the same spring rate its still gonna handle like a CR. Plus I was gonna throw a little bit more camber in there somewhere. I'm not inviting you all to flame because I'm messing with the CR suspension so keep neg comments to yourself. Thanks, all positive and or usefull info would be greatly appreciated.
Old Nov 9, 2008 | 08:01 AM
EELPIE's Avatar
According to Sport and Compact Car (June 2008);
392lb/in (7.00kg/mm) Front
342lb/in (6.22kg/mm) Rear
Old Nov 9, 2008 | 12:53 PM
madcityEP's Avatar
lol i was just looking for that issue when i saw your post.
If Sport Compact is right then yeah.. that
Old Nov 9, 2008 | 02:00 PM
phoQ's Avatar
Cool thanks alot guys, this has been bugging me for a while. Is that the same issue that did the suspension comparison? If so I'd love to get my hands on a copy.
Old Nov 10, 2008 | 08:46 AM
jeffjanzen's Avatar
That's not an opinion, it's a hypotheses (aka: guess); and it will prove to be wrong.
By lowering the vehicle, you're moving typical suspension travel to a different area in the stock suspension's range of motion. Static geometry will change, and total suspension travel will decrease, which WILL affect handling, even with identical spring rates. C of G will be lower too, which also affects handling (usually for the better).
At the very least, you'll have to play with your alignment a bit to get it to feel the same as it does now. You'll probably end up with more bump-steer than you're used to also. The road-race guys can tell you how to fix that.
Old Nov 10, 2008 | 09:10 AM
phoQ's Avatar
case in point, I'm just gonna buy coilovers lol...
Old Nov 10, 2008 | 01:08 PM
robinson's Avatar
Dibbs on your CR suspension
Old Nov 10, 2008 | 02:04 PM
phoQ's Avatar
ok
kjalleda
Aug 8, 2010 08:55 PM
Cheers!
Jun 11, 2010 04:31 PM
merckx racer
May 3, 2010 03:31 PM
haoheomap
Mar 5, 2010 07:42 AM
samura1
May 3, 2008 06:26 AM
