Ap2 Rear Swaybar on ap1 for track?
Old May 22, 2009 | 09:50 AM
dan_uk's Avatar
Default Ap2 Rear Swaybar on ap1 for track?
I notice the Ap2 rear bar is less stiff than he stock 03 bar I have:
03 Rear 27.2x4.5mm (P/N: 52300-S2A-J01)
ap2 Rear 25.4x4.5mm (P/N: 52300-S2A-J02)
So given that I can only use swaybars front and rear to control wheel lift and balance a non-stagerred track setup...
Would it help to soften the rear bar as well as increase the front bar?
Could I run a medium stiff front bar say a 30mm whiteline and a softer rear bar in combination instead of just running an extreme front bar like a Saner?
Old May 22, 2009 | 11:11 AM
FormulaRedline's Avatar
Why would you want to do this? It will be slower; you should be able to achieve the same sort of balance but you'll have less overall stiffness.
Old May 22, 2009 | 11:32 AM
dan_uk's Avatar
well I don't like the way a realy stiff front bar makes the car feel and the understeer
I know a lot of track cars don't even run a rear bar
Old May 22, 2009 | 12:00 PM
Mrsideways's Avatar
Rather then saying you don't like the front bar.. try less rear tow.
Old May 22, 2009 | 12:22 PM
That's because a lot of track cars either can't run a stiffer front bar because of their series' rules, have already stiffened the rear springs with a set of coilovers, or are looking for a free way to fix the stock oversteer.
Old May 22, 2009 | 05:07 PM
jaeyon00's Avatar
i was under the impression that much stiffer front bar increases understeer
Old May 22, 2009 | 06:02 PM
P-CarDriver's Avatar
correct
Old May 23, 2009 | 05:49 AM
robinson's Avatar
I don't think this is that big of a deal. Heck, I've ran autox and HPDE w/o a rear sway bar on stock shocks/springs. I don't think that the reduced roll stiffness of a smaller bar with make that much of a difference vs having no rear bar.
Old May 23, 2009 | 09:25 AM
innovation's Avatar
how is your car handling (oversteer or understeer) or are u just asking for opinions before you head onto the track??
batguano
Apr 19, 2017 09:38 AM
S2000_916
Jul 30, 2016 04:02 AM
S2000Shifter
Jul 11, 2010 12:52 PM
kentarou
Apr 16, 2007 01:42 AM
