ball joint wrap (do you and what to use)
Old Apr 23, 2012 | 09:59 PM
boyguan's Avatar
Default ball joint wrap (do you and what to use)
I haven't seem much discussion about wrapping the ball joints but i do see quite a bit of people doing it.
I assume the purpose is to protect the rubber from getting worn from the extreme heat of the brakes.
what is everyone using for a wrap?
Old Apr 24, 2012 | 12:18 AM
Brian617's Avatar
Rob touches on it here and has a few pictures. Looks like it's just aluminum tape
http://robrobinette.com/S2000OffsetBallJoints.htm
Old Apr 24, 2012 | 03:49 AM
robrob's Avatar
Yea, I use Home Depot aluminum tape (in the tape isle) and it works great but the sweet setup is some kind of high temp asbestos looking cloth. Somebody had it on in a picture posted about ball joints. I use the front brake dust shields for brake ducting and the shields help control the heat. If you remove the shields the protective tape is really needed to protect all the rubber boots--front and rear.
Old Apr 24, 2012 | 06:57 AM
JBAutosports's Avatar
Former Sponsor
Rob - I just spent the last hour reading thru your site. It is invaluable, sir and thanks so much for putting that together. Great stuff!
Old Apr 24, 2012 | 08:24 AM
cadams05nfr's Avatar
Agree. Rob has tons of great info on his site!
Old Apr 24, 2012 | 08:56 AM
tekka01's Avatar
i just picked this up on amazon http://www.amazon.com/gp/product/B00...ls_o05_s00_i01
Old Apr 24, 2012 | 11:05 AM
chuhsi's Avatar
thanks. i was just looking into this recently
Old Apr 24, 2012 | 11:39 AM
boyguan's Avatar
is there a big difference on the header wrap and the thermo wrap? i would think that it is the same application.
header wrap keeps heat inside it seems while the thermo wrap seems to keep heat out?
Old May 2, 2012 | 12:16 AM
boyguan's Avatar
i just did my ball joint wrap.
i used some DEI header fiberglass wrap around the ball joint. I used safety wire to hold it on.
i didnt know if the silver stuff is better but this is what i had around and i didnt have to tape it on even though taping is easier.
Old May 2, 2012 | 08:22 AM
Looks like this will be a good project for one day when I get bored
Santenay
Mar 30, 2015 03:01 PM
passmans2kny
Jun 9, 2011 07:11 PM
gtg749m
Jan 11, 2010 01:06 PM
Ooalloems2koO
Mar 19, 2005 07:10 PM
Code3Smith
Jun 22, 2001 03:43 PM
