Brake pad selection
Old Apr 6, 2021 | 04:22 PM
Jakob Boedenauer's Avatar
Stock calipers with Girodisc front and Urge rear. Stock-ish power, aero, cheater 200s and 100TW tires (255s)
Winmax W6 front and W5 rear were nice, wear was decent but not great. Great fit.
ST43 front and rear, great wear, brake balance very rear biased. Pad backing was chewed to shape by a hamster and required filing down to make fit into calipers.
ST47 front and ST43 rear, brake balance still very rear biased. Very aggressive initial bite, probably fine with proper 100TW or slicks, but not street-ish tires. Same problem with pad backing. Wear was great, no bending.
Hawk DTC70 front and DTC60 rear. Decent balance, fit was good, pads burnt up in one weekend.
CSG C21 front and C11 rear. Great fit. Great balance. Cannot say anything about wear yet. Dust a LOT. So far the best combination i've found for me.
Old Apr 6, 2021 | 05:25 PM
starchland's Avatar
Originally Posted by Nate Tempest
Since you've got a 2006, it has EBD, so pad selection to maintain front/rear bias shouldn't be as important as with earlier model years. I'm not sure how much difference that can compensate for though. As far as what pads to correct bias from a BBK up front, it really depends on what BBK you have. Some keep near stock bias, whereas others shift it significantly.
is EBD turned off with VSA or a always active ?
Old Apr 10, 2021 | 10:58 AM
s2k4life_az's Avatar
I looked up the spreadsheet created for BBK's on front/rear bias. C43 is the front BBK I will be using with stock single piece rear rotors.
Old Apr 10, 2021 | 11:03 AM
When VSA is off EBD is still active as it maintains equal deacceleration rate of all wheels. If someone know something different, let me know. This is my understanding.
Old May 9, 2021 | 10:54 PM
Bullwings's Avatar
FYI - it looks like Raybestos ST42 pad compounds are being phased out and eventually discontinued. You'll either need to run ST43 F/R or step it up to ST47/ST45 or ST45/ST43 if you want to run a staggered pad setup.
camuman
Sep 13, 2018 02:28 AM
MattZ28
Jan 8, 2017 06:12 PM
Drdoc
Jan 4, 2017 10:45 AM
boltonblue
Dec 30, 2016 04:12 PM
neeman77
Forced Induction For Sale
May 11, 2015 11:28 AM
