Brake question
Old Feb 12, 2009 | 12:34 PM
Dr. Strangelove's Avatar
Default Brake question
This doesn't have much to do with S2000s but I had a problem on a track recently and I was wondering what you guys thought.
I was driving my friend's MR2 Spyder at Arroyo Seco in New Mexico, he had told me before I drove that the brakes had overheated before and to go easy on them. I took his advice and was much nicer on the brakes than I normally am.
Going into one corner, I pushed on the brake pedal and it got mushy, the car lost about 75% of its braking ability all at once and it felt like the ABS was firing. It was no problem as there is a ton of runoff at this circuit, so I just pulled off the track and stopped.
My friend is convinced it was his crappy pads, I was under the impression it was fluid, but neither would account for the ABS.
Another thought I had was that the ABS was sensing a wheel lockup when there wasn't one and was preventing me from further depressing the pedal, but I don't think that would account for the extra travel in the brake pedal.
Anyone have any ideas?
Old Feb 12, 2009 | 12:59 PM
mikegarrison's Avatar
Sounds like fluid to me, but he may have so totally overheated the pads that they were ruined. Either is possible.
I doubt it was actually ABS you were feeling, but I don't have any experience with that car, so I suppose anything is possible. Some ABS computers are not as robust as they should be.
Old Feb 12, 2009 | 01:05 PM
Squirtle's Avatar
sounds like fluids to me too.
Old Feb 12, 2009 | 01:23 PM
macr88's Avatar
You might be boiling the fluid in just the rear calipers. I'm guessing if you boiled the fluid in the front calipers you'd feel more of a difference.
I made the mistake of running stock pads on the rear of my S and had similar symptoms. I forgot I don't have control of bias like I do on the bike.. Oops!!
Check the rear pads to see if they're baked and bleed the brakes with a clear tube to see what the fluid coming out looks like. I'm guessing it'll probably be cooked if you boiled it.
Old Feb 13, 2009 | 04:24 AM
Thanks guys, I'll let you know when I find out.
Frank_C
Aug 3, 2018 04:13 PM
Ali_houston
Jun 24, 2009 04:58 PM
junsu
Feb 29, 2008 08:57 AM
forsaken
Aug 26, 2003 06:50 AM
2kturkey
Mar 26, 2001 05:10 PM
