Camber adjustment question
Old Feb 8, 2012 | 02:06 PM
  #21
legend4life's Avatar
Originally Posted by crash
I would just do that until your ready to step up to a full setup.
maxing the SPC's out like you said will make it very easy to setup.
For my car I run 4.5 front and 3.5-4 rear.
sometimes its more or less but that seems good
Wow that is a lot of negative camber. What spring rates/sway bars/settings is this with?
How did you come to decide on this much camber?
Old Feb 8, 2012 | 02:09 PM
  #22
Originally Posted by psychoazn
Originally Posted by legend4life' timestamp='1328617786' post='21391160
[quote name='psychoazn' timestamp='1328521195' post='21387248']
Get the J's/Hardrace in the front. Does it cost more? Yes. Does it give you peace of mind? Yes.
N1 Concepts will sell you the S1/S2, which eliminates the RCA plate.
What's the difference between the S1, S2, and the hardrace?
All these options are confusing. What are the pros/cons of doing this via upper balljoint, lower balljoint, offset bushings, aftermarket control arms, etc?
S1 = -2 camber
S2 = -3 camber
SPC pulls in the top of the tire
Offset lower ball joints push out the bottom of the tire (wider track width)
[/quote]
Thanks for the info. These numbers are how much they add over stock right? So if stock gets -2, S1 gets -4, S2 gets -5?
Is the only difference between them how much camber range they add? What about between the J's and hardrace?
Old Feb 8, 2012 | 02:25 PM
  #23
User 121020's Avatar
Not sure about the J's Racing vs Hardrace question.
I found that the J's S2 joints only added about 2 degrees of negative camber instead of the advertised 3 degrees. Here is the camber curve with and without the J's S2 camber joints. The dashed line represents ~stock ride height.
Old Feb 8, 2012 | 05:33 PM
  #24
psychoazn's Avatar
Is this all with the same caster?
Ian Fountain
Apr 26, 2019 06:32 AM
unowned
May 8, 2012 11:16 PM
plokivos
Apr 8, 2008 08:33 AM
timg
May 29, 2007 07:29 AM
fikses2k
May 12, 2005 08:02 AM
