Bilstein PSS9 Question
Old May 29, 2007 | 03:53 AM
timg's Avatar
Default Bilstein PSS9 Question
Hey guys,
I just installed the Bilstein PSS9 coil overs on my 04. They dropped the front 5/8" and the rear 1 1/8". That was at the middle of the shock settings. After installing them, I had the car aligned. In the rear, one side maxed out the camber adjustment at a minimum of 2.7 degrees. The other side was around 2.4. Is there any way to lower those numbers? Do I have anything to worry about when running that much camber? I'm thinking about raising the rear another 1/4" or more to try to decrease the camber. Thanks.
Tim
Old May 29, 2007 | 07:29 AM
nocal's Avatar
Generally dropping cars will increase camber. If you want less you'll likely have to raise it up or get longer upper control arms.
MB
Jul 10, 2016 01:14 PM
S2000_916
Jun 14, 2016 11:13 PM
Apex1.0
Aug 23, 2014 08:57 AM
solomon
Jan 17, 2006 11:02 AM
