cat-less engine temps?
2001 ap1 bone stock power wise
would running a test pipe lower engine temps? would this be safer for my car on the track?
can a stock cat handle track abuse? with continuous heat
would catless effect part throttle?
It will make enough of a difference, that I would want a tune. I don't think it will change your engine coolant temps at all. It can change your passenger compartment temps though as cats hold in a lot of heat.
A common failure on S2000 catalytic convertors is the front section of the honey comb cracking loose and then shifting back and sort of decapitating the secondary O2 sensor. More heat on track will probably lead to an earlier failure but only if the car sees pretty regular track use.
dv55xc
May 9, 2017 09:39 PM
