deleting abs
I autocrossed my S2000 once with the ABS disabled (wheel speed sensor went bad). I was surprised by how often I locked the inside front wheel trail braking into corners.
Two conclusions from this experience:
1. You may be using your ABS more than you think -- I was never conscious of the fact that my ABS was modulating the brakes until it stopped doing so.
2. The S2000's brake bias is far enough forward to be drivable without ABS, at least on an early AP1.
Originally Posted by tinkfist,Sep 23 2009, 08:41 AM
Later that weekend, I spun at 100mph mid-turn, went full on ABS, and hit a concrete wall on the inside of the turn instead of a nice big gravel trap on the outside.
Originally Posted by PedalFaster,Sep 23 2009, 02:33 PM
P.S. - Your engine bay will also look cleaner if you remove your intake and exhaust manifolds.
I think we've gone way above and beyond the OP's initial question.
I think the answer to the original question and many future questions by josh is:
1. Honda engineers don't suck.
2. No home garage or ebay mod is going to make a slow driver fast.
3. As for minor weight reduction mods... see #2.
Originally Posted by Andrew Wojteczko,Sep 23 2009, 12:16 PM
Billy,
I think the 05 and earlier S2k's won't have the rear bias issue with ABS turned off because they still use a prop valve. But I suspect the newer ones with brake assist and the other functions have gone to full ABS control much like the other cars you've mentioned.
Andrew
Andrew
FWIW all Koni Challenge ST and GS racecars utilize OEM ABS systems. Racecars without ABS systems have dual master cylinders and a lot of engineering and testing behind them to find the right balance.
Modern ABS systems (including the S2000) are VERY good. Don't disable it.
Originally Posted by krazik,Sep 24 2009, 02:20 AM
and I can confirm we have VERY rear bias stock. I've lost my abs on track before.Tires/geometrie/weight balance etc
i do lockup front first when the s no ABS
Here's a potentially interesting tidbit for you guys:
In a position I used to hold at a car manufacturer, we did some testing on ABS efficiency. Myself and a co-worker instrumented a car with GPS equipment and a box of accelerometers and measured deceleration from 85 to 0 mph. We did several stops with ABS on and then did several "best effort" stops with ABS off. With ABS on, braking for this particular vehicle was a little under 1G. With ABS off, I was able to get a peak decel of 1.1G's, but couldn't sustain it. It was really tough to hold a peak decel without locking a wheel, even for just a blip of time. That to me - for myself at least - means I'm better off with ABS on since I don't have the pedal control to achieve a higher consistent decel, especially in a performance driving situation. I'm sure some of you guys can do it and trail brake into a corner without any fuss
To the OP: dude, keep ABS on. The likelihood of you being able to stop better than ABS is pretty low. On the street in an emergency reaction, you'd probably do what most people would do - jam the pedal. ABS will keep you in check. In most modern systems you can even steer a little too, at least to avoid something.
