Forgestar F14 17x10, data thread
Old Apr 19, 2015 | 11:26 PM
  #141
kundanp333's Avatar
Thanks for keeping the thread going. Now can we get some pics please.
Old Apr 20, 2015 | 03:51 AM
  #142
bobby.is.rad's Avatar
Originally Posted by decepticondc5
Originally Posted by bobby.is.rad' timestamp='1429475098' post='23583680
[quote name='decepticondc5' timestamp='1429460923' post='23583533']Mr. Poi,
While taking pictures could you get some of the lug nut situation you were talking about on page 1? Also I would like to know if you are running oem style wheel studs or perhaps the ARPs with the lead in shape.
Thank you!
I'm in the odd position of having ARP extended studs in the rear, and OEM up front since I replaced my rear wheel bearings but haven't had a reason to touch the fronts yet. I definitely do wish that I had a little bit more thread up front, but so far it hasn't been an issue.
do you have this same offset? I currently have the regular length ARP studs on the front and the oem style on the back (or whatever length came pre-installed on the hubs when I bought them from doorman)
My thoughts are that I would probably be OK with the regular length ARP studs all around with these +55.
OE style regular length Vs ARP regular length:
Seems like there might be 1 or 2 more threads on the ARP.
[/quote]
+55 offset with Skunk2 extended wheel bolts: http://cms.skunk2.com/id/555/Black-Series-Lug-Nut-Set/
What pics are you requesting in addition to what has already been posted?
Old Apr 20, 2015 | 06:43 AM
  #143
King Tut's Avatar
Originally Posted by JJ7
^Different camber settings and alignment pieces may account for small differences.
King Tut, Ive heard Hoosiers dont use much camber. That may make fender clearance slightly harder for you. But Im not sure what camber is typical, nor how wide a A7 245 is compared to other makes. Should still be very doable with a little work on OEM fenders regardless.
Here is the guide for A7s:
https://www.hoosiertire.com/pdfs/TCTR7_A7.pdf
For optimum performance the Hoosier P-Metric radial tires require about 3 degrees of negative camber. There will be a trade off in maximum performance to maximize
wear. Generally, 1/2 degrees less than optimum will result in the best compromise for wear and speed. Less than 2.5 degrees negative can result in excessive wear
on the outer shoulder junction. Higher pressures are needed when the vehicle has limited negative camber.
I am currently running -3.5F/-3.0R on my Michelin Pilot Super Sports. The section width on an A7 245 is 10.3" so they are quite wide for a 245. I think they will work well on a 10" wide wheel.
Old Apr 22, 2015 | 02:00 PM
  #144
kundanp333's Avatar
Any pictures of wheels in different colors? Bronze?
Also, someone mentioned that +55s arent really +55s ... so what are they closer to? +50? +52?
I am leaning towards +50 but if the offset isnt really that offset then I want to make sure to up the offset to +52 or +55. Can someone confirm my understanding?
Old Apr 22, 2015 | 02:36 PM
  #145
thepoi's Avatar
Read the first post, section Offset Accuracy. My tape measure and flat edge is assuming center from the maximum extents of the inside and outside face.
Old May 1, 2015 | 12:12 PM
  #146
S2000_916's Avatar
I have a stock height AP1 and want to go wide as possible but still be staggered. So I am thinking 17x9 up front and 17x10 in the rear. What offset should I look into? Also may do a bbk in the future.
I'm just a weekend warrior and so 6-8 track events a year.
Old May 1, 2015 | 01:21 PM
  #147
thomsbrain's Avatar
Are you rolling fenders?
Old May 1, 2015 | 05:57 PM
  #148
DTP525's Avatar
Yep Hoosier 245 on a 10" is money. Why wouldnt hoosiers like camber?. Its not the tire that dictates camber, its tire probe readings that do.
Old May 1, 2015 | 06:40 PM
  #149
S2000_916's Avatar
I'm not against rolling them, but would prefer not to. Just seems like all the rolls I have seen don't look too great. Let me know both ways.
Old May 4, 2015 | 07:53 AM
  #150
King Tut's Avatar
My man. Still waiting to hear back from Jurrian, but I am definitely getting a set to try out.
