Front Sway Bar
Originally Posted by ShocK,Dec 27 2007, 06:00 PM
Ben @ aj-racing just recommende me changing the rear sway, the more I think about it the more it makes sense..... good thread
-Aaron
softer, sorry, forgot that part lol If you think about it if you get the proper softness in the rear this will allow the rear tires more movement and also allow more weight transfer to the rear during corner exit (thinking in autocross mindset) As long as your not packing the front tire your fine I think. But I'm a noob when it somes to S2K tuning, but once I get something adjustable I'll be playing around enough to figure some of this stuff out.
Originally Posted by ShocK,Dec 27 2007, 10:00 PM
Ben @ aj-racing just recommende me changing the rear sway to something softer(edited), the more I think about it the more it makes sense..... good thread
Andre
Don't forget that stock class autocross allows only a front bar change. Anything larger is a Good Thing but exactly how much is enough is the key. Most of us use the stiffest bars we can on AP1s since tire sizes are a problem. However, it's also up to the driver's style and other mods/adjustments as to what the preferred setup is.
-Dave
very nice reads here. I've been trying to determine the best combination for both front and rear for street/and mild auto x/track use(atleast for now).
I've been thinking a good uograde that will be sutible for both is going with something like a cusco/tanabe in the front, and the CR sway in the rear.
Anyone thought of this set-up?
The stock suspension is very, very good for a production car.
For Autocross the car is perfectly balanced with the right alignment and all else stock if you're on street tires. No need for a front bar. When you go to R's things change, I suspect the extra lateral force on the rear wheels cause some dynamic toe changes.
-Aaron
