Holley Hydramat
Old Sep 27, 2017 | 04:27 AM
  #61
s2kfinesse's Avatar
Originally Posted by ddess
ideally if you could cut a part of the pot on the passenger side and slide the mat though that opening it would be best. The OEM pickup leave us with one choice of mat. I'll mess with it in the upcoming weeks and see if I can get some data at the September track days
were you able to spend any track time with the mat installed?
Old Oct 7, 2017 | 08:18 AM
  #62
ddess's Avatar
Im a slacker. Did an event at ACS but didn’t put the mat in. Going to BW October 14th and I’m bringing the mat with me. Session one I’m planning on running from a full tank to see when I notice starve. Then put in mat and repeat. See if I can pass the starve lap with the mat. Should be able to tell if it works or not.
Old Oct 16, 2017 | 09:37 AM
  #63
s2kfinesse's Avatar
yeah that would be a good test. Were you able to test it?
Old Nov 10, 2017 | 06:13 AM
  #64
ddess's Avatar
So i was able to install the mat and get a full day on it. it did not help wth starve. What is probably happening is the fuel pump is out flowing the swirl pots ability to refill through the small slit in its bottom. The return dump on the mat isn’t enough to prevent starve
so for boosted applications it’s not quite a plug and play
Old Nov 10, 2017 | 06:58 AM
  #65
s2kfinesse's Avatar
thanks for the feedback. That’s what I’m assuming is going on.....makes sense that if you’re using let’s say 80% of the system the return wouldn’t be able to cover it.
What fuel lever do you start to starve at?
Old Nov 10, 2017 | 01:45 PM
  #66
sirbikealot7's Avatar
Damn thats unfortunate, I was really hoping this would be a viable solution instead of a surge tank.
Old Nov 10, 2017 | 02:16 PM
  #67
s2kfinesse's Avatar
agreed. I still think it could work....either by laying the mat over the edge if possible or laying flat the side of the bowl. Maybe it could be cut and flattened without removing the tank but I’m sure it would be ALOT easier and cleaner if the tank was out. If I get to that point I might just cut the tank open and have it welded back up
Old Nov 11, 2017 | 04:44 PM
  #68
ddess's Avatar
half tank it will starve, end of lap 4. basically when the fuel level is below the facotry swirl pot.
im thinking for NA it could be a solution. i tried rotating the mat towards the passenger side but it doesnt lay over the pot, it sticks up towards the top and isnt getting fuel contact.
so next step is cut a larger hole in the swirl pot to see if this helps. or just go aftermarket swirl pot.
Old Nov 11, 2017 | 07:19 PM
  #69
s2kfinesse's Avatar
thanks for the feedback. Was really hoping laying towards the passenger side would work :-/
jtpassat
Mar 26, 2009 11:53 AM
pininfarina456
Mar 15, 2008 05:07 PM
pellisS2k
Feb 9, 2005 07:33 PM
krazik
Feb 9, 2005 11:56 AM
honda9krpm
Jun 6, 2004 11:16 PM
