How much shock travel?
Old Mar 25, 2013 | 02:23 PM
Sebring AP1's Avatar
^ Doesn't look like you're all that low to begin with.
Old Mar 25, 2013 | 02:29 PM
s2000ellier's Avatar
just giving him an idea
Old Mar 25, 2013 | 02:40 PM
robrob's Avatar
If you start hitting bumpers you will know it
It depends on the bump stop. KW V3s have big fat bump stops that make it hard to really hit the bone jarring bottom. The downside is you hit the bump stops sooner.
Old Mar 25, 2013 | 02:44 PM
TWF's Avatar
TWF
Cut them down
Old Mar 25, 2013 | 02:55 PM
boyguan's Avatar
Ill try to snap a picture tonight. I just figure 1 inch of shock travel is nothing. I am starting to rub te bumper Alil as well
Old Mar 25, 2013 | 03:12 PM
//steve\\'s Avatar
How big are the bumpstops on the Eibachs?
Old Mar 25, 2013 | 03:22 PM
josh7owens's Avatar
I have this much...
And I use all of it besides this much...
800 lbs springs in the rear. If the car is going to only be ran on flat ground then you could get away with less but if they car is going to be street driven with bumps you want adiquite travel or this happens...
Check out my JRZ thread I talk about travel and give measurements somewhere in there.
Old Mar 25, 2013 | 03:49 PM
TWF's Avatar
TWF
Aren't those scratches on your shock from helper collar been on the top? If I was you I would put them on bottom.
Old Mar 25, 2013 | 04:02 PM
boyguan's Avatar
Bump stops are 1 inch or 1.25
I have way less travel than that on my shocks. Pics to come later hard to see with the wheel on
The jrz seems to have way more travel than me
Old Mar 25, 2013 | 05:57 PM
boyguan's Avatar
This is my height and as you can see rear travel is little. Hard to tell but it's about 1-1.5 inch. I think I should raise the car at least 0.75 all around
[attachment=36239:image.jpg]
[attachment=36240:image.jpg]
[attachment=36241:image.jpg]
Do you think it's enough ?
Attached Thumbnails How much shock travel?-image.jpg   How much shock travel?-image.jpg   How much shock travel?-image.jpg
