How to stop oil evoparation
The PCV is a vacuum leak to help vent the blow by from combustion. If you cap the PCV and just vent the front port on the valve cover you are eliminating the chance to suck oil/fumes into your IM and causes smoking while still allowing the crankcase to disperse the pressure build up.
my car is na, but in theory it should get worse with boost / suspension / good driver *i'm putting down over 2g's consistently around certain turns on my stock suspension.
Just got back from Billman, the test results are in
Compression is even across the board at 215
Leak down was 1% in cylinders 1 and 3
1.5% in cylinder 2
and 3% in cylinder 4
(i'm a firm believer in frequent oil changes)
I'm going to install a baffle in my oilpan or try and confuse the oil to stay baffled, then get an ap2 valve cover and drill a few holes, add a pair of moroso catchcans. I'll update the thread once i install everything and take it out to the track
For the record, my car doesnt smoke while drifting or autocrossing. It only happens on certain turns on the track and once in a blue on the street.
does anyone know if the canton pan still leaves the flywheel exposed?
1.5% in cylinder 2
Consider http://www.saikoumichi.com catch cans. They are really high quality, custom made to whatever you desire, and probably less expensive.
thanks for the tip, for 150 a pair of cans with a clean install, and easy access to drain the cans, win win win.
When originaly designed, this was true. PCV is also now helping to release crankcase pressure.
Justin, I just use a simple cap from the autoparts store. I left the actual PCV there its just capped. I basically did what Rob did except I have a small filter at the valve cover vs a vented catch can.
Rob's setup
http://robrobinette.com/images/S2000...catch_can4.jpg
Rob's setup
Originally Posted by JUSTINTHECOASTIE' timestamp='1409428659' post='23308909
What are y'all using to plug the PCV port on the valve cover?
Rob's setup
