How to trailer the s2000
As was posted, make sure whatever you get has remove able fenders. I haven't seen a trailer that would allow a track height s2k to open its door above the fender. Also, get a beavertail if possible. My trailer has one and I still need ramp extensions or 2x8. Without the beavertail, you will probably have to get longer ramps or "racer amps". 2x8's won't be an option
My econo-trailer's fenders are low enough to open the door above them on my lowered s2000. Also I can use the ramps without any ramp extensions.
Of course the wiring is crap so I'm not sure I can recommend it, but that's another story
Here's a pic of my weight distributing hitch with sway control bar. This setup will add years to your life if you tow on a regular basis. Even my F250 Super Duty diesel tows much better with it than with a standard hitch. I buy all my trailer stuff from etrailer.com.
Crash, you can see the suspension arms flex when you tighten ratchet straps connected to the lower a-arms. Get the T-hooks and do it right. Using the T-hooks works great for short trailers since the connection points are closer to the center of the car.
If you know someone with corner weight scales you can put two of the scales next to each other and place a 4x4 on top of the scales then lower the trailer tongue on it to verify your tongue weight.
Robrob, how much weight are you towing? I'm surprised you notice a benefit with the weight distributing hitch with such a heavy tow vehicle.
I tow with a 5.7 tundra, other than a bit slower acceleration you wouldn't know the trailer was back there. I suspect you're towing a much heavier load.
I use a uhaul trailer (~2000#), my car is 2700 pounds, and I prob have another 500-600 pounds in the truck.
I'll certainly let rob chime in, but that picture is of an enclosed trailer.
I now tow my open trailer with a new ecoboost F150. Frankly I still prefer the towing with the weight distribution/anti sway. It just makes the whole thing rock solid. Can I do with out it, yes; its just better with
I have a 05 v8 tundra to tow with
How much does a steel closed deck weigh?
All the ones I see are wood deck and I wonder where I can mount the d rings. I don't think I can drill into the deck and reinforce from the bottom
Keep in mind all the cargo carried in your tow vehicle counts against your total cargo weight. When you add in driver, crew, all the spares and gear you're going to be pushing 5000lbs even with a light trailer. Any tow vehicle pulling an S2000 will definitely benefit from a $120 weight distribution hitch. It's a nice investment in safety.
Trailer is about 1900 lbs and car is 2600 lbs, it pulled the truck very well actually. A little underpowered from a stop but felt very stable and braked amazingly well. I drove 15 hours through hills and it just drops a gear and continues to maintain speed.
