Killing oil pressure sensors
#22
iv had issue with innovate sensors also. They seem to be crap sending units. i switched sending unit to the motec sensor and have not had problems since. For fuel pressure i couldnt get a good read either. I put a flex line from the output on the fuel rail and mounted the sensor on the chassis. sensor likes not vibrating, works great now.
#23
can anyone point me to a place to buy replacement sensors?
I tried the one from glowshift but its not outputting the correct voltage.
http://www.glowshiftdirect.com/Repla...re-Sensor.aspx
I found some on JEGs but i am unsure which to buy...
and innovate's site doesn't list any info on a replacement part
#24
#25
Originally Posted by s2000ellier' timestamp='1381270385' post='22817739
gauge just displays 0 but the voltage coming from the sensor is pegged at 3.61v
the LogWorks data logger just reads 0 from the pressure sensor...
#26
Originally Posted by Mrsideways' timestamp='1381346042' post='22819373
[quote name='s2000ellier' timestamp='1381270385' post='22817739']
[/quote]
Czarny Called me when building his spec miata asking if he should install all these gauges for water pressure (to identify a leak early) and oil pressure and temp etc etc. I asked him... It's the last lap of the runoffs and your winning and your water pressure gauge drops to zero.... do you keep going and ignore it. Or do you stop.... He said he'd keep going. So I told him not to bother with the gauges.
#28
#29
#30
going to give this one a shot
http://www.ebay.com/itm/Pressure-tra...-/250799543734
