Lap belt mounting on a PCI mount
#21
Xene (03-31-2018)
#24
Did you read the thread? Drill the car and use backing plates.
#26
I attached them to the seat mount, except the outer lap belt I used the same bolt hole as seat belt harness. I know it is not the proper way since putting backing plates is the right way to go for the sub belts and inner lap belt. I plan to convert them eventually. Was just more convenient with the mounting bracket.
#27
At first I used the sub belt holes in the PCI mount. Then for whatever reason, safety, or trying to get the seat lower, I went with the tried, true and correct, drill through the floor with backing plates.
surfer_crx
11-17-2014 11:41 PM
