Lightening trunk / boot lid
Old Jan 1, 2013 | 01:52 AM
MB's Avatar
MB
Member
Default Lightening trunk / boot lid
On my race car I have an oem lid, with an APR 200 wing.
I've got the springs removed too, but not done the lock yet.
When I lift the lid, I'm completely amazed at how heavy it is, it's actually ridiculous! Takes a lot of effort with 1 hand, so the spri gs must do a lot of work. I've not yet removed the wing and weighed it, but its probably about 50% of each contributing to it.
Looking at dry carbon lids and wings appears to be expensive, but if I can save some kgs I'd be interested. Has anyone lightened this area?
Old Jan 1, 2013 | 03:37 AM
robrob's Avatar
I think a carbon lid is your best bet. With your wing you need the lid bracing.
I removed the lock and added a pull wire:
Old Jan 1, 2013 | 07:43 AM
JJ7's Avatar
JJ7
Thats pretty cool. I could run that wire/ strap to toward the front since mine is still a street car. Did you weigh the lock?
Old Jan 1, 2013 | 10:38 AM
99SH's Avatar
I just bought a carbon lid which weighs fractions compared to stock. How would you brace a carbon lid?
Old Jan 1, 2013 | 11:42 AM
robrob's Avatar
The lock is actually very light. I did the pull loop mainly to make it easier to open the trunk. I got the wire and wire crimp at Home Depot.
Old Jan 1, 2013 | 06:57 PM
JJ7's Avatar
JJ7
Ok, thanks.
Old Jan 1, 2013 | 09:34 PM
Nabu's Avatar
Mark, its actually the trunk being too heavy without the springs helping.
I have the exact same setup on mine but i do take the wing off every now and then.
The wing is very light on its own and i can only imagine that the force with which is pushing the trunk down is not actually THAT big (even though it has a big angle).
I also agree about the inside bracing + wing.
My trunk already has a small curve exactly where the wing mounts. It seems like the wing is pulling the trunk with a diagonal backwards force.
The previous owner of the wing had a dry carbon fiber trunk (cannot remember if it was J's or Seibon) and from what i remember he also had the inside bracing plus his trunk was a lot more bent than mine.
Old Jan 2, 2013 | 12:20 AM
MB's Avatar
MB
Member
Good info.
The problem is that most carbon lids weight the same as OEM, so getting a light one means dry carbon ££££!
Old Jan 2, 2013 | 05:50 AM
Clark's Avatar
This is a purely theoretical question, but could you run without the lid if your wing was mounted directly to the chassis in the trunk?
Old Jan 2, 2013 | 06:09 AM
daktruckie99's Avatar
The APR wing isn't very heavy. I know I have one. The reason it feels so heavy when lifting is due to the distance of the wing from the fulcrum. A lighter trunk or wing won't make a noticeable difference in lifting force which seems to be your unit of measure.
-Mike
