Low/Unknown Caster
Old Aug 5, 2011 | 05:44 PM
robinson's Avatar
Originally Posted by PedalFaster
Yeah, that's what I meant by "nudging the front subframe over a bit".
DOH! That's what I get for not reading you post all the way.
Old Aug 5, 2011 | 05:46 PM
robinson's Avatar
Originally Posted by TTMartin
I didn't think of it at the time, but, the reason the 'computer' couldn't read the caster is I had the 17X9 +63 wheels on, and it was looking for AP2V2 front wheels. So, I'll take it back next week.
I went out to Summit Racing and picked up a set of Longacre Toe-In Plates. So for Sunday's autocross do I run with the reduced caster (robinson), or do I max caster reducing straight line camber, but, inducing more camber in turn (robrob) and re-set my toe on my own?
Posts I've read stated that 2° camber front and 2.5° camber rear should have little effect on tire life, so is it worth reducing the camber and increasing the caster?
I want to get to the point I can do my own wheel alignments, and I would have picked-up a camber/caster guage at Summit Racing, but, the one they had in stock maxed at 18" wheels and my F250 has 19" wheels, the one for 17"-22" wheels is due in next week.
FWIW, I chose static camber vs camber gain with suspension compression because of my stiffer springs causing less suspension compression.
Also, I don't see how a different wheel would make a difference during an alignment.
Old Aug 5, 2011 | 05:51 PM
//steve\\'s Avatar
The wheel shouldn't make any difference in the machine's ability to read any measurement. If it is then it's a crappy machine and I'd go elsewhere. I've had my brother do multiple alignments for the current and past s2k I had and they've all had non-staggered wheels and never had a problem with it being able to not see caster or any other measurement.
93silvergt
May 27, 2015 02:25 PM
mrbond413
May 18, 2014 09:57 AM
eremoy
Apr 12, 2014 06:27 PM
t.vo408
Jun 9, 2006 05:38 PM
jguerdat
Feb 21, 2002 06:46 AM
