Most cost effective way to neutralize handling?
#31
Originally Posted by payneinthe,Oct 10 2004, 12:20 AM
Service manual says:
Camber Front: 0.5 deg +- 0.5deg (1.0deg is within specs)
Camber Rear: 1.5deg +- 0.5deg (2.0deg is within specs)
Total Toe Front: 0" +- 1/16"
Total Toe Rear: 1/4" +- 1/16" (want to convert your specs to inches?)
Does it list a wider tolerance somewhere else? Ah, up in the front it lists the 0.5 deg tolerance as the inspection limit -- the 0.17 deg tolerance is the adjustment limit.
#32
Looks like I've found a local auto-x event for Nov 13/14. I'll be able to attend the Nov 13 event. My first auto-x I will actually be a participant in.
So, prior to that. I will of course get an alignment. Judging from the info I gather from reading all this... I'm guessing the following settings are optimum for street/occasional track on bone stock suspension?
Front:
1.0 deg camber
0" toe
Rear:
2.0 deg camber
1/4" toe
That the general consensus? Thanks for all the great advice by the way.
Front:
1.0 deg camber
0" toe
Rear:
2.0 deg camber
1/4" toe
#33
More or less. One thing you should be aware of is that the "UK alignment" is actually developed for high speed driving, not specialized for autox. But it should be fine for now, and much better than the "some random alignment that may or may not even be in spec" alignment that the cars generally have when you buy them.
