Nov SCCA Fastrack: S2000 moves down to BSP
#21
Do you guys have any experience with BSP Datsun 240Z's packing 280Z motors? Our region's FTD is dominated by one like this and nobody has been able to touch his times in over several years.
I'm wondering if there are any that show up at the national level with this kind of prep and how well/poorly do they do?
#22
The 240Z used to be very dominant, but its run seems to be over. There is a very fast Z that runs our local anything goes class with a $25000 crate motor and similarly priced sequential transmission. Search for "Rusty Old Datsun"... you should find a little bit about its pedigree.
#23
...I'd lower and stiffen the suspension, and put on great big wheels and tires (limited in SP only by willingness to flare fenders. You could run Corvette size tires.) Probably change final drive gears...
So, a bench racing summary for a BSP S2000...
>'04+ MY platform
>Triple adjustables riding as low as tire clearance allows and then deal with flares
>17X9's in the front with ? 245/45's ? & 18X10's in the rear with 285/30's
>Urethane suspension bushings, motor mounts, tranny mounts, diff. mounts
>Adjustable FSB and slightly larger diameter rear
> X-brace in front (any need to bother w/STB's? weight vs. gain in stiffness?)
>ECU tuning w/lower VTEC engagement point & raised rev limiter (way raised)
>CAI, larger bore throttle body (legal in SP ?), header, test-pipe (cat removal), $15 straight exhaust or $2K single exit titanium
> ???cc injectors, high flow fuel pump, fuel pressure regulator (tune w/ plugs that match new A/F ratio)
>Removal of A/C, all stereo components, replace steering wheel, replace seats, strip badges, find the lighter MY pieces for front/rear fascia-interior door panels, insturment cluster, etc.
>Functional rear spoiler?
>Petition for C-3-4 to be bumped to ASP in '06
>Drive like hell
SM2? Add:
>Super-charger (Existing kit or piece built? Roots?)
>2 way cable type LSD?
> Carbon fiber hood? Any lighter? Venting engine bay a plus?
>? Educate me...
FP? Add (& delete):
> No S/C, but custom made pistons, rods, cams, retainers, valves, springs
> Port & polish, shave head, extrude honed intake manifold
> Dry sump system
> Adjustable upper control arms
> True slicks
> Big calipers & rotors - be wary of weight, and have to have 16's fit over 'em
> Pillow ball & metal bushings where applicable
> Custom C.F. drive shaft
> Cryo treated tranny with 4th to 6th gears removed
> Carbon and/or fiberglass doors, 1/4's, trunk & hood
> Fuel cell and Solo 1 rollcage
> Gut it - false headlight/taillight assemblies, entire interior gone, stripped doors, no glass (even windsheild), etc. May be a bitch in the rain.
> VAFC & Data acquisition
> Torque supression device
~ 2150-2200 lbs.?
#24
Originally Posted by tmorrow,Oct 6 2004, 08:59 PM
Final drive changes bump you to SM2, correct?
A lot of the stuff you list under FP (adjustable arms and all the drivetrain stuff) is totally legal in SM2. The main differences are SM2 requires a DOT tires, full interior, and you can't relocate suspension pickup points like you can in FP.
#25
Got to quit trusting my memory. I sure thought bolt in final drive gears were OK Did this used to be the rule?
Anyway for this car maybe lower gears are not the way to go, considering the very usable 1st. Maybe give up on avoiding first and just make it even more useable.
So why not run larger tires? 305 or 335/30-18 are 1.2 inch larger diameter than BS tires. (Hoosier spec sheet) They will fit with fender flares. You can handle the 1/2 inch ride height increase with suspension adj. First gear top speed would go up 5% from 42 to 44 and 2nd from 64 to 67 (using oem 2.0 rev limit).
If you can exit the corner faster (same tires, less weight) that offsets accel advantage.
And Corvettes are often grip limited from using full power from slow corners.
And while tires sre heavier, it may be possible to get lighter wheels, since you are no longer stck with factory offset.
#26
Originally Posted by jzr,Oct 6 2004, 01:12 PM
I think the car is more viable in SM2. Ian, How do you think the S2000 would be with a supercharger like Palmblad's Miata?
However.... Running a blower like Bob's is going to create 200+ ft/lbs of torque out of vtec. Can we say BLOWN TRANNY/DIF/AXLES. If you can re-enforce that stuff then sure a 25XXlbs S2000 would do very very nicely in SM2. Another car I'd love to try. That Twin Screw Supercharger is very very nice. We could see high boost levels virtually right off idle. I think with the 15lbs pulley we could see 10lbs of boost by 1500rpm or something insanely low like that. No ramp up effect like a turbo or to a lesser degree a eaton or centrfigual blower. The only thing that suffered with the blower was throttle responce. As with any F/I car you have to fill all the intake plumbing with pressure before the engine gets it. So even though the intake track was very short you still had that split second of normal miata power before you got the rush of 280rwhp. It was easy to drive around but when I jumped back in the S2K I found myself going to throttle to early(and praying for more power). Kinda like after you spend time Autoxing an Automatic.
#27
Originally Posted by Jason Saini,Oct 6 2004, 07:59 PM
Look back over the past few years' results... BSP has run with, or actually beaten ASP at most events. The fact of the matter is that there is little difference between an ASP Vette and a BSP Vette.
-Andy
#28
JOIN ME IN SM2 NOW!!
