Ohlins DFV Review
Yes, they are there to allow the spring to stay perfectly perpendicular to the shock shaft, which should give better performance and enhance the longevity of the seals, etc. Similar to what you get with AST 4150 top hats, & KW Clubsport top hats. I'm having a hard time deciding between AST 4150's, the Ohlin's DFV's, and KW Clubsports. All can be had with springs in the 450-700 lb range, and all can be had with spherical bearing top mounts, and they they are all adjustable, although the Clubsports have independent control over compression. Thing is, is the independent compression adjustment worth taking the NASA TTC hit in points? You only get 20 total to play with before bumping up in class. The AST 4150's with their lack of external reservoirs and single adjustment, cost you much less points ... and may yield the same effective performance when setup right? I also wonder if the Ohlin's DFV fall under "single" adjustable or "double" adjustable, because adjustment changes both compression and rebound. I would assume single adjustable, as I'm guessing the biggest benefit to double is the independent nature of each adjustment.
Great review Anatoliy. One of my favorites. Definetly give us some track impressions as you gain track experience. I defiantly have a few track guys out their that love their DFVs over Konis, Tiens & KWs.
BTW, the next Batch of 5 DFVs is coming in December, we bought 4 and pre sold 2 of them already, the 5th is already sold to another company. Let us know if you want one of the last 2 of the year for Christmas.
Next Batch is coming in the Spring.
Hey Andrew, I remembered reading about you waiting for these when I was writing that "notes" section. Several expletives were yelled out after I put the front end back on the ground and realized that I had to redo everything because of those stupid bearings! It really shouldn't be that hard for Ohlins to put sticky labels on the plastic bags (ie. Front springs, Rear springs, Front bearings, Rear bearings, etc.)
https://www.s2ki.com/s2000/topic/983...t__p__22876505
Cool, glad to hear!
Have not been able to really lean on these the past week due to weather, but thanks to Patrick's suggestion, street driving has been a dream! 10 clicks from full soft allows the shocks to completely soak up majority of road imperfections and bumps. With these settings I literally don't feel when I'm driving over the reflectors dividing the lanes. Granted we don't have those massive ones like the guys in Florida do, but still, on Konis and Eibachs it was very noticeable, whereas with these I just hear a little noise. Steering is still very sharp, handling is still great and there's very little squat under heavy braking.
psycho_s2000
15
Mar 27, 2005 02:45 PM
-Yz-
May 12, 2004 09:01 AM
