OT: Alternative ways to mount a GT wing?
Hi there, sorry for being Off topic but I am about to mount my gt(cheap/ghetto VIS
double deck aluminium special) wing on my SS, it will be a weekend hpde,
canyon thing.
I am just want to see if there's any other way to mount a wing effectively without
drilling more holes on the trunk. The reason i am asking this is because i saw an
S with a tire carrier and wing mounted on a aluminium rack which is attached on
the thrid brake light hole.
Let me know if you created or saw some clever solution on the track.
THANKS
jason
canyon thing.
THANKS
jason
If you want to avoid holes, buy a spare rear decklid from a breaker yard and swap out your trunk lid when you HPDE your car. If that's not an option for whatever reason, yeah, you could mount a trailer hitch or similar device (I recently fabb'd one to be used as a bike rack for a friends IS350) on the bottom of your trunk and run aluminum poles or something upwards and mount the wing on that. It's gonna flex a lot more at speed than a regular trunk mount unless you make it uber heavy, though.
you can just cut a long strip out instead and do this
http://www.tcdesignfab.com/pages/wingupright-03_jpg.htm
Originally Posted by stocky,Dec 27 2006, 10:31 AM
can you explain the pictures ?!
This is the wing setup that I saw that didn't require holes drilled. It's alot of extra weight over just mounting it on your trunk and seems like more trouble then just swaping trunk. Looked really well built though.
Originally Posted by HunterEz,Dec 27 2006, 07:22 PM
Those are the mounts to Rylan's wings. They go through the trunk and bolt directly to the body. Though, in order to run them, he had to cut some slits in his trunk. ASM has the same setup on their wide body time attack car.
Oh I see no holes in the trunk caus ethere is no trunk!
Vboy
Feb 16, 2013 11:00 AM
BerlinaBayRidah
Jan 13, 2007 05:43 AM
one post up
