Please interpret these alignment specs.
Old Feb 13, 2004 | 07:22 PM
  #21
ken o's Avatar
[QUOTE]Originally posted by payneinthe
Old Feb 15, 2004 | 05:31 PM
  #22
krazik's Avatar
Administrator
The toe numbers seem backwards too me. Is toe in represented with a positive value and toe out with a negative value?
In front + is toe-out and - is toe-in and its flipped in the rear.
Its nice of them
Old Feb 15, 2004 | 06:32 PM
  #23
ken o's Avatar
OK now I am totally confused. So I went and measured the distance between the rear wheels.
From the front of the tire it is 58 1/8 " from the rear of the tire it is 58 1/2".
$1,000,000 question: Is this toe in or toe out? Too much?
Ken
Old Feb 15, 2004 | 06:48 PM
  #24
payneinthe's Avatar
If the fronts are closer together, it is toe in. If this is the rear, it seems like it's pretty close, given the accuracy of whatever you're using to measure.
Old Apr 11, 2004 | 07:36 PM
  #25
rlaifatt's Avatar
Had an alignment done yesterday and am wondering if the toe specs are okay for the track. Front is 1/32" left and 0" right (close enough to zero total), and Rear is 7/32" each side, for 7/16" total toe-in (assuming that positive number in the rear means toe-in). For Rear I asked for 1/8" each side for 1/4" total, but the tech could not get it there. Is 7/16 total toe-in rear reasonable ?
Camber is -1.9* front and -2.5* rear (both the max he could get), running 245/45 17 front 275/40/17 rear, shaved street tires.
Old Apr 11, 2004 | 07:43 PM
  #26
jzr's Avatar
jzr
7/16" is an okay value for autocross, but too much for the track, especially with the big tires you'll be running. I'd go for 1/4" max, and be tempted to just run zero; it'll help tire life as well as handling.
I thought the car toed-out in bump, so it doesn't make sense to me that he can't get it to zero with your lowered suspension. If -2.5* is the least amount of negative camber you can get, that could be the limiting factor. Have them loosen everything up and see how much you camber you can get at zero toe - if he can only get it back "up" to -3 then that's probably okay. More than 3.25 is going to be a bit much...
Old Apr 11, 2004 | 07:53 PM
  #27
rlaifatt's Avatar
Jason, remember I am running big tires in the front also, so I thought the rear might be unstable with zero toe, which he did get at one time, but 7/32 was the next measurement of toe-in he could get (I think the machine wasn't calibrated finely; looked old). Also, with the downfoce of the wing on higher speed tirns, will that create toe-in or out?
Old Apr 11, 2004 | 09:27 PM
  #28
shaggy's Avatar
The tech could only get within 3/16ths of your specified rear toe number? He sucks. You will notice a difference between 1/4" in and 7/16" in. The car should be a bit pushier and it should suffer a little bit in a straight line.
It sounds like a LOT of toe in to me, but I come from Subaru land. I'm used to a rear toe setting of 5/8" toe out in the rear. I'm still getting used to the whole idea of toe in.
Andy H.
muha22752
Aug 24, 2012 02:10 PM
nuklearmaniac86
May 21, 2008 04:10 PM
jonam
Aug 29, 2005 10:11 AM
SRTRick
May 23, 2002 11:06 AM
AG Y2K S2K
Sep 8, 2001 07:03 AM
