Please support this...
I think it's hard to say what works even at this point though. I wish this wasn't the case but Im sill seeing people win with all kind of diffenet spring set-ups. so keep the spring rates close and some are like 300in/lb difference front and rear. Same with the sway bar, I've seen people run stock bars all the way up to the 1.375 br on full stiff. I wish we could just say hey "this is what works", or "this is the range of what works and tune within that range to suit your driving style." I would say we could wait till nationals and have the top 3-5 guys (Mainly CRs though, haha Just kidding, we won't go there.) chime in and list there set-ups and settings but the odds are none of them will want to give that much info. We could us that info and see what overlaps and then make a FAQ.
Getting the top 5 s2000s to post their full set-ups is very unlikely.
I'm a firm believer that the driver makes the most difference. Car setup for a national winner may make a local driver nervous. If my car wins a trophy I'll tell all, but it's not like anyone could just copy the setup and win.
This said, yes I am running a CR "delete" and yes, it appears to conflict with what I'm saying. I special ordered the car new in '08 because I liked it, not for any other reason. Now it happens to be the favored car.
I have found most the other S2000 guys are open with their setups. The problem is, nothing is proven at this point. My main concern for STR is to keep the rear stable. In every STR prepped car I have driven, rear stability is key. If I cant keep the rear stable, I cant be competitive. There are other factors for different course designs (like Toledo) but most of the National course flow well and are mostly higher speed maintenance.
-Marc
For an STR FAQ thread, these are my ideas:
Take the most trusted builders and National-Grade STR drivers and ask their composite wisdom on different topics.
I'm thinking Fiedler, Yom and Glagola to start if they're willing. Marc, I'd ask you but you've just joined the class recently. .
Originally Posted by BirdShot' timestamp='1312254077' post='20837657
[quote name='josh7owens' timestamp='1312252147' post='20837582']
-Marc
[/quote]
I agree with what Marc says about the rear end. I've made certain choices based on funds and current equipment that are not the same as others. But in the end, I can toss the car around.
I'm not saying right or wrong here, but for me the range of allowable adjustment is part of winning in this kind of class. Much less so in stock classes of course, everyone is on nearly the same setup and driver skill prevails. With STR say, driver skill still prevails but the car can start to affect the results more. A good driver on a bad setup might do the same time as a mediocre driver on a good one perhaps. Of course a good driver who has taken advantage of the rules and has found a good setup for him or herself can dominate.
Without sharing, why ask in the first place? That's kinda what a forum like this is about, isn't it? When I first started racing in b-stock, there was a top level driver that wouldn't share his setup info. It really took the fun out of it and began to root against them. The guys and girls in this sport that keep me coming back and have my respect are the ones willing to help you out and make you better. Do what you want, but if you wish to have your own secret setup, maybe figure it out on your own? Sounds like that is part of the fun for you? I could see that. Building something from scratch isn't my t, that's why I rely on many of the guys on here. Since I use this resource for my info, it woudnt be fair not to contribute when someone asks me.
-Marc
-Marc
I guess when it comes down to it though, after I worked and worked to find what pressures, camber settings, shock settings and everything else that gives me the best opportunity for a win, I am not so quick to say "it is these pressures, this camber, this toe and this stiffness that got me the win". (but who's to say those settings would even work for the next guy I guess)
I made my STR AP1 thread for anyone to see, I would hope there will be some helpful things in there for others down the road, but I'm not going to post everything is all I'm saying. I guess that sounds pretentious...again, not what I am going for! I don't know, it's 2am I will see how bad this reads in the morning...
