ProSolo in a 2004+
Old Jun 28, 2005 | 09:51 AM
Orthonormal's Avatar
Default ProSolo in a 2004+
Honda beefed up the transmission and differential for the 2004 model. That's good for ProSolo. But they also added that clutch damper thingy, which I activated the first time I made an abrupt shift into 2nd gear.
Does that thing prevent you from doing clutch-drop starts like you'd want to do at a ProSolo?
Old Jun 28, 2005 | 01:07 PM
ronbauer's Avatar
Annie and I ran our car at a "Practice Pro" locally and I only got three starts before the clutch started slipping.
That said, I apparently don't drop it as hard as others do.....
Ron
Old Jun 28, 2005 | 03:39 PM
GrimReaper's Avatar
If you're referring to the clutch delay valve on the slave cylinder, you can change it out with an '03 to limit slippage. Looks like a pretty easy DIY. There's a great writeup about it in under the hood.
https://www.s2ki.com/forums/index.php?showtopic=270439
hth
-sam
Brownergy's Avatar
Remove the clutch delay valve. It's a mere 10 minute process and will make the car so much more responsive, prolong the life of the clutch, but could cause differential failures if you clutch dump a lot.
Old Jun 28, 2005 | 03:47 PM
PR151's Avatar
I don't think removing the delay valve is legal in AS.
Old Jun 28, 2005 | 08:27 PM
PedalFaster's Avatar
Removing the clutch delay valve or replacing it with one from an earlier car would not be legal.
You might want to PM Bob Klingler ("bkr"?) and ask him -- he's run his car at at least one Pro.
Steve
BKR's Avatar
BKR
If you ease the clutch out on the 04, you will immediately smell the ugly slip. In ProSolo's, we've learned that you can't afford to think about it; just drop it. Then there's no slippage problem and the 275's never spin too much-- unless the surface is wet.
BK
Old Jun 29, 2005 | 11:28 AM
Thanks Bob! That doesn't sound too bad. 275s! Maybe I will have to get one...
branden2k
Jan 29, 2007 12:55 AM
S2Kabob
Jan 18, 2007 08:34 AM
04HondaS2k
Jun 3, 2006 10:25 AM
x s2k x
Nov 9, 2005 01:04 PM
redtr4
Jul 20, 2005 10:35 PM
