Question about antisub belts
Old Oct 12, 2009 | 05:00 AM
ideugene's Avatar
Default Question about antisub belts
I had a question regarding antisub belts. I was reading that 20 degrees was ideal. I wanted to mount the eyebolts as far back as possible so my seat won't touch them when I push the seat back. I'm not sure of the angle this would make but I wanted to confirm that it was still safe.
Thanks
Eugene
Old Oct 13, 2009 | 03:01 PM
ideugene's Avatar
help?
Old Oct 13, 2009 | 03:19 PM
mikegarrison's Avatar
No idea. My seat doesn't slide.
Look in the mounting instructions for the belts. They probably show a range of acceptible angles.
Old Oct 13, 2009 | 03:27 PM
cuonice's Avatar
Yes, it will be "safe." Different manufacturers suggest slightly different mounting locations. Schroth (the harnesses I use) recommends the sub-straps be anchored slightly behind the driver at around a 20* angle. Any reasonable distance behind the driver "should" be fine. What is reasonable? I can't be certain; I bet the manufacturer of your belts has an opinion
With something as important as restraints, if you have questions about installation you should check with the manufacturer of your belts. Different belts are engineered to work in slightly different ways and therefore their ideal mounting locations vary slightly. I wouldn't trust the random guy on the internet (me)!
Old Oct 13, 2009 | 03:40 PM
ideugene's Avatar
Willans just says... The location for crotch strap mounting should be to the rear of the driver and 10" to 12" apart. I got the 20degrees from Scrotch.
Old Oct 13, 2009 | 04:13 PM
Just follow the instructions that came with YOUR harness.
Middlesbrough
Dec 10, 2013 05:04 AM
Blindeye_03
Jul 3, 2012 05:26 AM
Goggles Paizano
Jun 29, 2005 12:58 PM
joe9k
Mar 25, 2005 03:26 PM
so_weahd
Jan 5, 2004 01:47 PM
