Racing Brake vented rear BBK
Old 10-22-2010, 12:34 PM
  #31
hondaf1's Avatar
the more interest they get, the faster they are going to expedite things.
Old 10-22-2010, 05:40 PM
  #32
Neutered Sputniks's Avatar
Well, I'm definitely interested in the +2 rear kit and the full BBK in the front...just not sure when I'd have the money for it all.
Old 10-28-2010, 06:21 PM
  #33
hondaf1's Avatar
the rear +1 BBK arrived today and is on the car. will do some testing this saturday at NJMP with NASA TT. once testing is completed, then MPG will start to take preorder. the special preorder price is limited time only
also got word that the front BBK should arrive next week. just in time for me to test at summit point next week with nasa mid-atl
pics will be up soon.
nb12 (11-17-2019)
Old 10-28-2010, 07:56 PM
  #34
hondaf1's Avatar
Old 10-28-2010, 08:38 PM
  #35
Voodoo_S2K's Avatar
Originally Posted by hondaf1,Oct 28 2010, 08:56 PM
Old 10-28-2010, 09:32 PM
  #36
robrob's Avatar
The +1 rear kit looks great. Let us know how it performs on the track. I've been running RacingBrake 2 piece rotors for 2 years now and I'm very happy with their quality, performance and longevity. I got 23 track days out of my first set running stock calipers and Carbotech XP10 pads. I was cracking stock rotors about every 3 or 4 track days so they've actually been a money saver. After 23 track days I finally had a small crack that made it to the outside edge of the rotor ring. I simply bought new rings and bolted them up.
I just put 6 hours of track time on a set of Accord calipers and XP10 pads using a 1.5mm spacer sourced from hondaf1 (the op). My previous set of stock caliper XP10s only lasted 3 hours & 15 minutes so the Accord caliper upgrade is working out great. I'm really looking forward to adding a +1 kit to the rear.
hondaf1's thread on the Accord caliper upgrade is here:
https://www.s2ki.com/forums/index.ph...ic=747034&st=0
Rob Robinette
Old 10-28-2010, 09:56 PM
  #37
GrandMasterKhan's Avatar
can these be bought without the slots?
Old 10-29-2010, 03:26 AM
  #38
hondaf1's Avatar
the rear BBK will come in Open Slots or Blank rotors, but no plain(regular) slots. i specifically requested RB to produce plain cut rotors because i knew most racer -prefers non-slot rotors.
the Open Slots is what i have in the rear (pic above)
I'm not sure what rotor surface will be available for the front, but Open Slot will be available for sure.
Old 10-29-2010, 11:33 AM
  #39
Orpheus's Avatar
fyi--just spoke to carbotech and they said they will make their pads to any thickness you want, for no additional surcharge. so... i'm in wheneverz.
still not sure whether to get +2 or +1 though. will have stoptech front bbk, but stoptech said that the system is designed to have a compatible torque balance with the oem rear, and thus upsizing the rotors without a complimentary change to the caliper sounds like it would throw off stoptech's balancing. perhaps +1 is more appropriate.
Old 10-29-2010, 12:16 PM
  #40
hondaf1's Avatar
thanks for informing us. good to hear that Carbotech will offer custom pads with the correct thickness at no extra charge.
you can alway use different pad compound to adjust brake bias. if the larger rear rotor increase braking torque over oem, then use a less aggressive compound (which will be better for the rotor anyways).
Quick Reply: Racing Brake vented rear BBK
