Ran Calabogie- Need help with brake diagnostics!
Old Oct 5, 2007 | 07:19 PM
Borbor's Avatar
there's nothing wrong with ferodo pads.
your choice of the compound was wrong for the application; therefore, they disintegrated. My friend's EK runs Ferodos (not your compound) and they're perfectly fine for track use.
Old Oct 6, 2007 | 09:02 AM
rwheelz's Avatar
well, for this application, should I be going with the 3000 or the 3500?
I am using OEM rotors.
Also, is there a caliper available that will allow me swap pads easily like with a wilwood or brembo setup, or do I have to do a massive upgrade. I just want swapping pads to be even quicker.
Old Oct 6, 2007 | 01:50 PM
tinkfist's Avatar
I believe you just answered your own question
Old Oct 6, 2007 | 03:27 PM
Borbor's Avatar
Unless you're running a w2w enduro event (10 hours + ) where pitstop comes into play, I fail to see how the stock calipers prevent you from a quick pad change.
If you have your stuff together, it shouldn't take longer than 10 mins per wheel and that's from the time you get the jack underneath the car to the time you finish torquing the wheel back on.
Greyout
Apr 13, 2016 07:21 PM
bobby.is.rad
Sep 10, 2013 03:12 PM
Ch0pper
Aug 26, 2008 06:16 AM
UNC04SuzukaBlue
Jul 11, 2005 09:01 PM
dwb1
Sep 20, 2001 04:28 AM
