Reminder about safety when using a jack
Old Apr 8, 2005 | 07:48 PM
rlaifatt's Avatar
Default Reminder about safety when using a jack
Just a reminder to not trust the jack to hold the car up. We all hear and know this but sometimes we forget. At Infineon last Sunday I wanted to swap around rear wheels because of uneven wear, and decided to jack up the rear only using the jack under the diff. I was in a hurry and lazily didn't use my jack stands which I had (like most of us do every now and then). I got one wheel off when the jack failed and the rear fell to the ground (rotor hit ground, so luckily my foot wasn't there). Had to use a couple other jacks to get that corner back off the ground. So a reminder to be careful.
BTW, there is a good sale on on the Big Red (by Torin) aluminum racing jack with twin-pistons and a pair of fancy aluminum 3000 lb jack-stands all for $129 after rebate at Pep Boys. It's super smooth, more leverage, and a lot nicer than the Harbor Freight that I had. However, it does seem a bit heavier and larger (like the Sears jack).
Old Apr 9, 2005 | 06:56 AM
jonam's Avatar
holy crap!
Glad to hear you didn't get hurt!
so was it HF aluminum rapid pump racing jack?
Old Apr 9, 2005 | 07:03 AM
NoTorq's Avatar
Also, the Sears 3000lb aluminum low profile jack is on sale for $88 right now. Much better than my $24, POS, 392-pumps-to-lift, steel jack!
Old Apr 9, 2005 | 07:51 AM
aklucsarits's Avatar
Great reminder, and great advice.
No matter what kind of fancy, expensive hydraulic jack you have under your car, you are still entrusting your life to the $0.02 O-ring in it that keeps your car supported.
Andrew
Old Apr 9, 2005 | 10:38 PM
Nobody's Avatar
In addition to using jack stands--make sure that whatever the jackstands (or jacks) are resting on is solid. I was under an Audi on the side of the road when I discovered that 6" away from where I had placed the jack the road was hollow--I could literally push it in by pounding it with my fist.
Old Apr 11, 2005 | 04:45 AM
Triple-H's Avatar
Scary story!
Glad you were not under it...
Old Apr 11, 2005 | 07:24 AM
DongTran's Avatar
Do you by any chance have a link to that sale? I cannot find it on their website. Maybe it's regional?
I need a new jack
Old Apr 11, 2005 | 09:01 AM
rlaifatt's Avatar
The Sears sale for the 4000lb jack is from $199 to $179. The $88 jack is a smaller jack, probably not different than all the other single-piston 3000 lb jacks, but don't know for sure..
Old Apr 11, 2005 | 09:18 AM
jonam's Avatar
$88 jack is heavy (50# or something) due to steel + aluminum construction. No the one you want to bring to the track..
Old Apr 11, 2005 | 10:21 AM
twohoos's Avatar
Yep, the $88 jack *looks* like the lightweight aluminum ones, but is actually steel, and much heavier. Still, probably a good buy at under 90 bucks.
