Roll Bars
Why? You can't get the seat any further back. I guess you could incline it more, if you want.
I'm hoping for something sortof like 3312DC has...his is the closest to what I'm picturing anyways. SCCA legal, in basically the same spot the stock bar is but higher, but still enough to allow soft top operation. From what I've seen, you can gain a few inches over the stock bar height and lower yourself a few inches with racing seats, and then pass the infamous "broomstick test".
Originally Posted by alejo,Dec 29 2006, 11:00 AM
i know you posted pics of your bar before but i can't find them, can you post them please?
(I'm actually so much of an uber-geek that I don't bother too much with common tech toys like cameras and PDAs. I tend to play more with Crays....)
Originally Posted by Jek,Dec 29 2006, 11:17 AM
It's nothing to do with where I sit. I actually sit farther forward than you'd think, there's plenty of room for a bar behind my seat. It's more that I want the bar as far from my head as possible so I can still drive and be marginally safe without a helmet.
Any bar that works with the soft top is going to sit where the ELDA bar does. That's a function of the soft top, not the bar.
If you get rid of the soft top, then you can move the bar back a little and up higher. You don't really want it too far back, though. At least, the harness bar wants to be within eight inches of your shoulder. Also, the farther back the bar is, the more you are relying on the windshield frame to not collapse. And (unless you plan to make the car totally open) the less height you have under the hard top.
IMO, the best spot for the bar is where I have it, right about in line with the front edge of the rear shelf. That's where most bars and cages end up. I was very worried about that location with the stock seats and belts, but in the harness and race seats I'm much less concerned about hitting it. This is another reason why you have to consider the whole safety system as a totality.
I've got a bar that replaces the stock hoops and bolts into the stock bar holes. It was custom made ( I picked it up used ) ( built at Lucas shop in Houston ) but it looks just like the Mugen bar photos.
The bar is the max high for the softtop , and is as far back as you could reasonably go. My harness bolts into it and it's got tabs welded in to guide the stock belts for when the stock seats are in.
The downside is that it's not as wide as I would like and I would like it to be higher.
It appears to be a decent compromise for a weekend street car / track car.
If I don't use it as a daily driver would you suggest getting the full cage? I'm guessing that a full cage will run about $2000-3000. About how much would I be looking at for a custom rollbar?
A cage is much safer than a roll bar in a roll.
If your fab charges that much for a cage then I'd guess proabably $1k for a roll bar. TCD charges much less but thats not an option for you.
-Ry
-Ry
