S2000 fitment for Fluidampr
We put in a call to Fluidamper 5 months ago and worked with them to measure, design and test a Crank damper that offers better vibration protection than OEM for our highly stressed motors
S2000s that are Track or Auto-crossed frequently spend a lot of time at elevated RPMs where crank deflection & vibration are at their greatest. Elevated RPMs accelerates engine wear and an aftermarket crank damper is simply better protection for your engine and reduces engine wear similar to using synthetic oil. Also, the OEM crank damper is part that gets worn out and needs to be replaced like brake pads or your clutch. It is designed to dampen crank vibrations by turning them into heat. Heat is not a friend of rubber and overtime it will wear it down reducing its effectiveness. Older S2000s should replace this part especially if it has been tracked a bit.
Full details @ URGE designs
Please visit our Market Place page for Pricing
Email us for questions
Every built motor we build will have this damper installed it!!
Viscous type Crank Damper
- Inertia Ring suspended in silicone gel in side damper hub vs Bonded to hub via rubber O-ring like OEM or other aftermarket dampers
- Silicone is more heat tolerant than rubber & will not need to be rebuilt/replaced during life of your engine
- Wider range of harmonic damping due to free floating design, rubber designs have narrower range of damping
- Reduced Engine wear on bearings, timing chain & valvetrain (crank vibration shake everything attached to and run off it)
- Noticeably smoother engine at idle and typical driving conditions, valvetrain is quieter as well
- Possible HP gains due to "weightless effect" read here for details
- Designed off OEM damper, not modified K series damper
- OEM diameter so it drives all accessories at Honda designed speeds
- Should fit Kraftwerks Supercharger as it uses OEM Crank Damper
- We are waiting on bolt patterns from Vortech, Comptech and SOS to verify fitment
Thank you for being a fried of URGE designs. How are the brakes doing?
I am interested in the FI header you're working with ASP though
