S2000 fitment for Fluidampr
Old Oct 18, 2013 | 09:58 AM
  #31
Voodoo_S2K's Avatar
Generally an impact gun doesn't work so well on the crank bolt, as the crank ends up absorbing a lot of the impacting force. The Honda tool works the best, but it does take a lot of force. This can seem like too much, if you have never done it before.
Old Oct 18, 2013 | 10:43 AM
  #32
mLeach's Avatar
I've had great luck using impacts on crank pulley bolts on other hondas. since the force is generally rotational, I can't see it harming anything.
Old Oct 19, 2013 | 07:18 AM
  #33
Urge's Avatar
Sponsor
https://www.s2ki.com/s2000/topic/985...-bolt-removal/
This should help
__________________
Old Oct 19, 2013 | 10:19 AM
  #34
bruthaboost's Avatar
Originally Posted by stlandy
I had the Honda tool against the shock tower and roughly 4' of leverage with the jack handle on the bolt with no luck. I have some Freeze Off penetrant so maybe try that. Did you have to replace the seal when you did the install? Just get very nervous when having to apply that much torque to something to break it loose.
You really have to put quite a bit of muscle behind it. The motor will rock from the amount of force you have to put into it.
Old Oct 19, 2013 | 04:50 PM
  #35
stlandy's Avatar
Got it done, let it soak with PB Blaster over night and it finally broke loose this morning. Thanks for the other tips.
Urge
May 24, 2017 04:47 AM
hippos2k
Dec 3, 2009 10:09 PM
Engine_Guru
Aug 14, 2007 01:45 PM
BlueIrishS2k
Jan 18, 2003 07:21 AM
