S2000 in H2 for Nasa Honda Challenge?
Old Jan 6, 2011 | 07:31 PM
  #81
Liquidsation's Avatar
I think they must remain oem and that would be connected with oem components. If it is disconnected then it is considered altered which you must take points (Edit: if it was PT or TT).
Old Jan 6, 2011 | 10:06 PM
  #82
krazik's Avatar
Administrator
points? in h2?
Old Jan 7, 2011 | 03:25 AM
  #83
^You're right, I was thinking PT. I'll edit my post.
Old Jan 7, 2011 | 05:14 AM
  #84
SandM's Avatar
I think, as far as HC goes, instead of points you just add weight.
I'm just assuming, but as a factory prepped car, sway bars of approved origin, would have to be mounted and connected as per factory specifications.
Old Jan 7, 2011 | 06:11 AM
  #85
dan_uk's Avatar
to go a bit off topic.. but would it be possible to loose up a rear swaybar if say your bushings had deteriorated or it wasn't done up too tight?
Old Jan 7, 2011 | 06:52 PM
  #86
jlucas's Avatar
Originally Posted by krazik,Jan 6 2011, 05:50 PM
do the way bars have to be connected?
You think there's an advantage with only CR spring rates?
Old Jan 8, 2011 | 01:02 AM
  #87
krazik's Avatar
Administrator
just a possible solution to over steer and "square" tires. faster, I donno, it works better on a stock diff to keep the rear wheel down.
-Ry
Matty0624
Jan 29, 2018 11:49 AM
az3ar
May 19, 2012 06:59 AM
Fyrestrike
Apr 17, 2004 06:34 AM
