seat belts vs harness
#21
That makes the install and routing of the harnesses immensely annoying. Plus you're going to have issues mounting the inboard harness with the buckle in place.
I do 2 hour drives to summit point and NJMP and 4.5 hour drives to VIR wearing harnesses without issue. If you really have a concern about it, buy Schroth Profi ASM harnesses. You can still add the crotch strap to them, and the breakaway portion will allow your body to move in a crash and let the airbag do its thing.
If it's about parking lot speeds, I just loosen the shoulder straps while I'm in a lot so i can look around better and tighten them back up when I'm on a main road.
#22
thomsbrain,
How do you have your outboard lap belt secured? I'm using one of these with clip in hardware on the harness:
I figure if schroth says it's ok for mounting I think it's safe enough. I could never get an eye bolt to fit outboard with the BC rails in place , it stuck out too far and interfered with the slider
#23
So Duffman...I took your lead and made a call to Corbeau yesterday. They informed me that many of their seats (including your FX1) is compatible with stock seat belts for street driving. I'm curious why you need to swap it out rather than simply replacing the stock seats? Ingress and egress issues? I also noticed that their Forza Sport is FIA approved and they tell me is should fit our cars too. See any problems with that seat?
#24
A few reasons:
1. Ingress and egress is annoying with the buckets - they're high on the sides so you end up essentially falling into the car. It's super annoying with the top up. For the record, the Corbeaus have fairly low thigh bolsters too compared to some other options.
2. The shoulder wings limit mobility within the vehicle for me (I lift enough that I'm wide up there).
3. There really isn't enough room to run the inboard strap and the seat belt receptacle simultaneously, and if you do the routing on the lower part of the lap belt as well it interferes with the ourboard lap belt strap too. That would mean any time you want to use harnesses, you would have to pull the seats , remove the receptacle, and route the lap belts anytime you want to use the harnesses.
4. The last part is cosmetic - my wife hates sitting in the buckets, and I hate the way the car looks with mismatched seats, so I do what I think looks nicer.
Chibo (04-17-2017)
#26
thomsbrain,
I want to say I used one of those for the inboard location, too (with a backing plate on the transmission tunnel).
