Shift times between gears?
Old Jan 13, 2006 | 03:55 PM
  #21
mikegarrison's Avatar
In terms of using the datalogger for shifting evaluation, I have actually been more interested in looking at my downshifting. I thought that most of the time I was pretty smooth, but the accelerometers don't always agree. You can see every little jerk on the car, and it shows I have some work to do in terms of heel/toe technique.
Old Jan 13, 2006 | 03:58 PM
  #22
krazik's Avatar
Administrator
Originally Posted by rlaifatt,Jan 12 2006, 03:59 PM
SOW, which is the shortest track at 1.5 I think, is 11-12 upshifts (plus similar number of downshifts!). I am usualy sore after a weekend.
Thinking.. 11-12??? really??
CCW: 4>3>2>3>4>3>2>3>2>(3>2)>3>4 yeah damn 11 or 13 total shifts,
so not 12 upshifts as you said, still a lot in 1.5 miles
CW: 4>3>2>3>2>3>2>3>4>3>2>3>4 - 13 shifts
Old Jan 13, 2006 | 04:04 PM
  #23
fencepost error: Rather than counting the numbers, count the carats (the actual shifts). otherwise you double count the "4" on either end. Unless you skip gears, the total number of shifts should be even....
Old Jan 13, 2006 | 07:19 PM
  #24
rlaifatt's Avatar
I think we were both wrong. For stock gear, AP1:
CW: 4>3>2>3>2>3>2>3>4>3>2>3>4>3>2>3>2>3>4 (18)
CCW: 4>3>2>3>2>3>4>3>2>3>2(>3>2)>3>2>3>4 (14-16)
Old Jan 13, 2006 | 07:35 PM
  #25
rlaifatt's Avatar
[QUOTE=jzr,Jan 13 2006, 02:53 PM]This (incorrect) correlation between an increase in shift speeds and the decrease in lap times is often made.
The thing to note is that while person A may be shifting more quickly than person B, person B is not stopped while they are shifting - they are still moving along at their pre-shift speed.
Old Jan 13, 2006 | 09:54 PM
  #26
Originally Posted by rlaifatt,Jan 13 2006, 08:35 PM
it is much more important to brake smoothly to settle and control the car for the corner than to brake harder late
But it is better yet to brake later without braking harder, and to carry more speed through the corner! Within the obvious limits, of course.
Old Jan 14, 2006 | 05:52 AM
  #27
ellisnc's Avatar
The thing to note is that while person A may be shifting more quickly than person B, person B is not stopped while they are shifting - they are still moving along at their pre-shift speed. What they're missing out on is that much extra moment of acceleration.
In most all cases, spending .x less time on shifts will not result in a .x quicker laptime, it will in fact be something smaller.
This often comes up as an argument against shorter gears, the argument being that the extra time spent shifting will negate the extra thrust, which usually isn't the case.
Jason you're right... there is no direct (1:1) correlation between shift time and lap time lost. But as twohoos (sorry, don't know your name) said, when you start getting into the area of babying the gearbox, it's very easy to see how much speed it's costing you at the end of the straight.
On a very long straight like the one at VIR, the Civic Si I was in was in 5th for what seemed like 10 seconds and you come out of a second gear corner (Oaktree) so your speed out of that corner and shifting times and points (how high you actually revved the engine) was a major factor in the lap time. This is unless you screwed up something else in the lap.
When Matt tries this at his next track day and posts data, you all can see.
I still maintain that this is still a worthwhile subject because you're not doing anything else on the straight as far as controlling the car than upshifting so you may as well try to optimize it!
JLCY2K
Nov 30, 2006 02:17 AM
XLeezardx
Jun 14, 2005 09:52 AM
JSfetko
21
Sep 12, 2004 09:14 AM
TubeDriver
Sep 12, 2003 11:55 AM
lostsol
Oct 17, 2002 12:13 PM
