Shocks for STR
Originally Posted by Orthonormal,Jul 10 2010, 08:36 AM
Drew, did you have the 8100, 8300, or 8660 compression cans?
No the adjustment is pretty even across the range but I am using a linear piston on the compression side with a good amount of preload in the stack so it has a mild knee at 0.5 in/sec. I'll likely go D/D on the next rebuild as well as taking out the rebound mentioned above.
You can see the original dynos here: http://www.alvanderp.com/pics/penske%20dynos.pdf
The fronts have since been rebuilt for more compression, as I was maxing out the adjustment range on concrete.
[QUOTE=alvanderp,Jul 10 2010, 05:29 PM]No the adjustment is pretty even across the range but I am using a linear piston on the compression side with a good amount of preload in the stack so it has a mild knee at 0.5 in/sec.
Drew's rebound side looks digressive, too. SRP seems to know some tricks, so I believe that they could have made a digressive/linear piston behave as shown on Drew's plots.
Drew, that looks like a wonderful amount of low-speed compression adjustment. My max and min curves lie on top of one another up to about 2"/sec before they gradually diverge. It's actually very sad to look at, and I hope SRP can do a lot better for me.
I am not saying it cannot be done. I would just ask why you would want to? What's the reason why you would want a digressive curve with a knee at such a high force?
A digressive curve typically works to eliminate high forces at higher rates (i.e. greater than the low rates where good handling is desired)? The goal would be to absorb high speed inputs and keep the tire on the ground.
Originally Posted by Random1,Jul 10 2010, 10:00 PM
While it "looks" digressive the knee in the curve is at 600 to 700 lbs. A digressive setup would be down lower more in the region (100 to 200 lbs) of where it is for compression. The typical digressive knee is also at lower rate.
I agree interesting things (digression) can be achieved with custom designed shim stacks on a linear piston, but these curves are typical for Penske from what I have seen.
Are you trying to say that in your experience Penske linear rebound pistons flatten out like that at x force(defined by the shim stack) regardless of the position of the adjuster?
My rebound curves look exactly like a friend of mine's 8300's with a dual VDP setup, that's why I ask.
