STR Prep - ECU and Tuning Discusson
Old Sep 10, 2013 | 07:53 AM
  #781
mLeach's Avatar
you could probably setup a partial parallel sub-harness, where you could control the engine directly with the haltech, and use the stock ecu to run the rest of the crap. Remember, all you have to do is be able to plug something in, and have it talk to an ecu.
Old Sep 10, 2013 | 10:15 AM
  #782
ConeKiller2's Avatar
Marc,
If anyone is interested the haltech and the aem can be made Str legal. The aem I had was Str legal. In fact I still have the harness to make it work if anyone wants a real tuning solution
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
Old Sep 10, 2013 | 10:34 AM
  #783
ebdavis's Avatar
Interested! Tell us more.
Old Sep 10, 2013 | 11:02 AM
  #784
This is something that tuners have done for years. The create a piggyback harness for the standalone that allows the OEM ecu to do all things like immobilizer, emissions, obd etc and then allow the standalone to do all the fuel/ignitoon/timing etc. This is how people run standalone where emissions testing is still done. This is why I thought the rule change to piggyback only was ridiculous. Like I said if anyone want to make good power you can use an aem and use this method. I still have the harness if anyone is interested and can put you in touch with the tuner that can make it all work properly for you.. My 04 with stock header, knn intake and Str exhaust made 235/160 on a dynojet
Old Sep 10, 2013 | 11:21 AM
  #785
s2000ellier's Avatar
Do you have a contact who can make the harness to use both an AEM EMS and OEM ECU?
Old Sep 10, 2013 | 11:43 AM
  #786
yes i have the tuner here in florida that can install it. It was used with my aem when i ran in str and is completely ready tested and almost brand new since i moved to bsp shortly after. pm me if interested
Old Sep 10, 2013 | 11:52 AM
  #787
your pms are full
Old Sep 10, 2013 | 11:59 AM
  #788
ebdavis's Avatar
Shutup and take my money!
Old Sep 10, 2013 | 12:05 PM
  #789
OK PMS SHOULD BE GOOD NOW!
Old Sep 15, 2013 | 05:23 AM
  #790
aspen's Avatar
I've been following this...
Few thoughts on the Haltech side. If it exposes some form of interface (a la, OBD data words over USB), wouldn't it be possible to use a microcontroller or something as an intermediary between the factory OBD2 port and the Haltech datawords? OBD is a pretty simple standard, as far as all of the requests it's required to fulfill. It's the manufacturer specific ones (as well as additional functionality) that would be the tricky part.
Seems to me like it'd be pretty straightforward to do this... Anyone had similar thoughts?
