STR Prep - Suspension and Alignment
Old Jan 5, 2012 | 01:41 PM
  #41
s2000ellier's Avatar
Originally Posted by oinojo
all of these are illegal for STR
Sorry, that is what I thought I said.
Old Jan 9, 2012 | 12:59 PM
  #42
daytrip00's Avatar
My adjusters were all frozen, so i'm taking the opportunity to upgrade to these hardened bushings. I bought a partial set of the Mugen ones when King had their black friday sale. It seems that King has all the bushings except the one i circled below. Anybody have any comments about going Mugen all around and Spoon for the circeled one?
Anybody have any thoughts on mixing the two?
EDIT: Oops, I got it wrong. It looks like both are missing the bushing opposite the one I have circled. From Spoon's diagram, it looks like the rear upper arm can accept the same bushings as the front upper arm. That means you can get the same set for either.
Old Jan 9, 2012 | 01:59 PM
  #43
murderedrsx's Avatar
Probably isnt going to make any noticeable difference. Id go ahead and do it with stockers or powerflex or spoon if i were you.
Old Jan 10, 2012 | 02:17 PM
  #44
littlewing1208's Avatar
Are most people using 2.5" or 2.25" springs and what top mounts/perches? I stumbled upon some relvalved koni's and I'm trying to figure out length and diameter of spring to buy (anyone selling? ).
Ooopse, I'll repost this on the damper/spring thread....feel free to delete.
Old Jan 12, 2012 | 04:20 PM
  #45
FlyinFatass's Avatar
Originally Posted by murderedrsx
My front lowers squeek. Haha. Its annoying. Silicone spray lasts for about a day. I antiseized the bolts and lubed the bushes on install too. I just ignore it, and hope the competition thinks my cars janky.
I've applied marine grease on the poly bushings on my Z3 before i installed them. It lasted about 2 weeks before it started squeaking. I've looked a little, but it seems that there really isn't a long term method for keeping them from squeaking.
Old Jan 13, 2012 | 06:39 AM
  #46
Random1's Avatar
Is there enough space to get a layer of Teflon tape in there? I use Teflon tape for my poly sway bar bushing and it works great. I do PM once per year and replace it.
Old Jan 13, 2012 | 03:16 PM
  #47
rrthorne8's Avatar
I know this may be throwing a wrench in things....
but i have some questions on the spc upper offset ball joints, has anyone else noticed that they are taller then the oem ones?
isnt this almost the opposite of what a roll center adjuster is supposed to fix?
what effects on handling may have taken place by essentially spacing the front or rear upper ball joint?
what affect does this have on the rules>
Old Jan 13, 2012 | 03:31 PM
  #48
nlink720's Avatar
I just installed these this week. Tomorrow I can measure them and the oem ones since they are still laying around.
Old Jan 13, 2012 | 03:36 PM
  #49
nlink720's Avatar
My only question was how much camber you guys can get out of the joints since they will not reach full negative camber without grinding away a little of the ball joint. I'm sure I will have enough to get -2.8 or so degrees, but would like to know that before taking it to get the alignment. (Google "rob robinette SPC ball joints" to see what I am talking about) Mine is limited to about 3/4 of the available travel at the moment.
Old Jan 14, 2012 | 06:53 PM
  #50
bronxbomber252's Avatar
when I put the SPC ones on, I already had my camber bolts maxed, after installing the SPC's at max camber, I was at something like -4.5, so I used the OEM adjusters to get - 2.8
