Stupid question about steering wheel hubs
Old 04-07-2003, 03:22 PM
Bassem's Avatar
Default Stupid question about steering wheel hubs
I am wondering about anyone's experience with the spoon steering wheel hub for those of you who had switched their wheels out.
I have one of these hubs, and measured the fuse looking resistor at 1.8ohms. I am of the understanding that the system checks for a 2ohm resistance in the airbag, otherwise it detects a "fault". Has anyone used it successfully (without it throwing the light)?
If it still did not fool the srs, what did you end up doing?
My brother tried it, and he says his still shows a light. I am getting my steering wheel in soon, so figured I would ask around before i ended up like:
thanks in advance,
bassem
Bassem is offline
Old 04-16-2003, 12:25 PM
AJ PwR's Avatar
I changed my steering wheel as well but I was using HKB hub adaptors. The light didn't come on.
AJ PwR is offline
Old 04-16-2003, 05:02 PM
Bassem's Avatar
does hkb sell the eliminator separately?
thanks for responding,
bassem
Bassem is offline
Old 04-16-2003, 05:53 PM
vapors2k's Avatar
all the eliminator is..is a 2ohm resistor.
vapors2k is offline
Old 04-16-2003, 06:19 PM
Bassem's Avatar
vapors...thats what i thought. i measured the resistance of the spoon resistor and it was 1.8ohm. the resistance of the resistor and the wires was 2.2ohms...would that slightly higher resistance make the difference?
bassem
Bassem is offline
Old 04-16-2003, 06:46 PM
vapors2k's Avatar
bassem
probably not. I'm using 2 1ohm resistors for each of my seat belt retractors wired in series to get 2 ohm b/c my electronics shop is out of 2 ohm resistors.
vapors2k is offline
Old 04-16-2003, 07:49 PM
Bassem's Avatar
considering ceramic resitors are rated to be within 10% and the normal resistors are usually 3 or 5%...i guess that should alright then.
thanks
bassem
Bassem is offline
casey.r.fitz
01-04-2015 05:33 PM
Samson
09-08-2011 07:37 AM
death_blossom
07-26-2009 02:19 AM
Mr. Francesco
07-07-2008 06:09 PM
Ro_Ja Boy
02-01-2005 01:08 PM
Quick Reply: Stupid question about steering wheel hubs
