T2 S2000 rule changes
Old May 26, 2004 | 05:12 PM
  #21
krazik's Avatar
Administrator
"Just measure the back spacing you would need and call John up."
I'll call him tommorrow. He's assuming stock offset most likely.
Old May 26, 2004 | 05:53 PM
  #22
ellisnc's Avatar
Rylan, we tried the stock wheels vs. my Spoon wheels at the track this weekend... stock tires on both.
The Spoon wheels made the car understeer a little more but it was a whole lot more stable in the one slow corner on the track. I have the 45mm offset for both ends and of course the rims are 1/2" wider on each end. I'm not sure the actual rim width should be a variable in the comparo though. Anyway, the toe settings were 0 in the front and on the minimum edge of toe-in spec in the rear.
I'm pretty sure we'd want the highest (numerically) offset for the wheels and then just play with spacers to change the track width. We'll probably use some Comptech studs anyway.
Cataclysm
Nov 11, 2005 06:14 PM
Tom Jr
Mar 18, 2005 04:54 AM
Red_Ohio_Rocket
Mar 8, 2004 05:44 PM
kenlola
Jan 9, 2004 07:57 AM
Syntax
Aug 4, 2001 04:38 AM
