At Thunderhill - shifting problems at speed
Old Aug 31, 2012 | 09:07 AM
cracknut's Avatar
Default At Thunderhill - shifting problems at speed
Hey guys.
I'm out with SCCA at Thunderhill right now and first practice didn't go so well. I had all sorts of problems shifting down or up in gears 3-4-5. Didn't try 2nd on track. Sometimes the 5-4 downshift would go ok but not always. I couldn't even get into 5th reliably on the straight. I'm sure the clutch was fully depressed each time.
Other clues:
- clutch fluid full and clean and was bled last winter
- haven't checked tranny fluid yet as I don't have a big enough socket. Can ask around the paddock for that.
- car shifts fine around the paddock in gears 3-4-5 at revs < 6k. I didn't try high-rev shifting cause I couldn't really get enough speed for that safely.
- clutch engages when the pedal is almost fully released
- clutch is not stock - don't know which aftermarket one tho and was installed by SoS several years ago
Qualifying at 1:30p PDT!
Old Aug 31, 2012 | 09:34 AM
cracknut's Avatar
Checking tranny fluid first, then clutch pedal adjustment.
Old Aug 31, 2012 | 10:42 AM
cracknut's Avatar
Tranny fluid full.
Old Aug 31, 2012 | 11:08 AM
Andrie's Avatar
Someone need to be down there and check the slave while you press the clutch pedal. See if the slave has full range and not leaking.
Old Aug 31, 2012 | 02:10 PM
cracknut's Avatar
Good idea.
Also, when I was adjusting the pedal I noticed that the boot was leaking. See attached file. It looks like it's been leaky for a while as there's a minor mess on the floor below it.
Attached Thumbnails At Thunderhill - shifting problems at speed-leakyclutchpedal.jpg
Old Aug 31, 2012 | 03:56 PM
s2000ellier's Avatar
the method to fix the leaky pedal is to every 1k miles or so, remove the fluid in the reservoir, wipe the reservoir clean with a paper towel, then refill. you shouldn't need to bleed for that. after a while it will stop leaking
Old Aug 31, 2012 | 09:51 PM
Andrie's Avatar
You have a bad/leaky master cylinder. I'm afraid there are no correct fix other than replacing the unit
Old Sep 1, 2012 | 05:02 AM
cracknut's Avatar
Do you think that's causing the shifting problems? I wOuld guess no since the car shifts fine in the paddock.
Old Sep 1, 2012 | 08:58 PM
Andrie's Avatar
Definitely. You shift faster on track, so the problem magnify.
Mbudz
Feb 12, 2008 04:08 AM
s2kon
Oct 15, 2007 01:48 PM
klee1113
Mar 20, 2007 10:50 AM
smalls777
Aug 2, 2006 03:36 PM
Duncan
Nov 27, 2004 07:02 PM
