Track clutch
Old Mar 9, 2012 | 08:25 AM
zslow6's Avatar
Default Track clutch
Hey guys need to replace the clutch and was curious what you guys recommend for track use? Car has a comptech sc on it now but will prolly be coming off. Not looking to spend an arm and leg on a twin disk either but dont think its really necessary. Would appreciate any input you could give.
Old Mar 9, 2012 | 10:00 AM
gen2gsr's Avatar
How tight is the competition you run with? For casual open track, and even moderate time attack, oem clutch is great since it saves shock to your diff. If tenths of a second matter to you, then consider upgrading the clamping force. I use an oem clutch with a light chromoly flywheel.
Old Mar 9, 2012 | 11:11 AM
psychoazn's Avatar
OP is boosted.
If you get an aftermarket clutch, be sure to keep an eye on your engine mounts. You'll want to get an engine torque damper and/or aftermarket mounts, as hard shifts from the harder grab will eventually break the OEM ones.
Old Mar 9, 2012 | 11:23 AM
gen2gsr's Avatar
I assumed he would remove the sc the same time he got the clutch installed.
Old Mar 9, 2012 | 09:33 PM
sweetdill's Avatar
AP1 or AP2?
If you have an AP2, browse this article:
Demystifying the AP2 Drivetrain
Old Mar 11, 2012 | 09:33 AM
zslow6's Avatar
im considering doing nasa tt plus i want something with a stronger pedal feel and engagement stock was a bit to soft for me. Yes i do plan on taking the sc off when the clutch goes in. are there any specific clutch anyone would recommend or stay away from?
Old Mar 11, 2012 | 09:52 AM
99SH's Avatar
For a boosted car, I'm running a stock disc & ACT HD pressure plate. This will hold your boost and keep the system reliable. Tons of people are running this setup successfully This setup is inexpensive and will give you a firmer pedal.
Old Mar 11, 2012 | 01:50 PM
dan_uk's Avatar
I have the OEM disk with ACT pressure plate and a lightweight comptech flywheel, works great the car only makes 210HP though
spoonertuner24
Apr 1, 2013 09:55 PM
igottademo9
Dec 6, 2010 11:28 AM
philipminge
Feb 27, 2010 07:03 AM
s2kfrog
Feb 11, 2010 08:25 PM
yeaitsahonda
Jun 27, 2008 06:02 PM
