Trailing edge of brake pads missing chunks
Old Feb 20, 2011 | 01:20 PM
tbakker's Avatar
Default Trailing edge of brake pads missing chunks
I'm running Hawk HT-10 front and rear and found that the trailing edges of the rear pads have lost chunks of material, some up to 1/4" wide and 1/2" long. There are also a number of cracks in the main body of the pad. Is this normal? Should I use these pads again? They are 1/4" thick so they have enough material but i'm concerned that the chunking will continue and be a hazard. The front pads seem fine, no cracks, no missing chunks. I hadn't experienced any problem with braking before I pulled these off. They were on for 3 track days + about 3k miles of moderate DD.
Thanks for your help!
Old Feb 20, 2011 | 02:46 PM
cuonice's Avatar
Without seeing what you are talking about, I think it is safe to say that you should replace the rear pads before your next track excursion. Sounds like the pad compound is delaminating from the backing plate.
Old Feb 21, 2011 | 06:06 AM
scareyourpassenger's Avatar
Sounds like they went over the designed temperature range.
I had some hawks that did this as well and moved up to a better pad.
Old Feb 21, 2011 | 07:33 AM
tbakker's Avatar
Thanks for the feedback - I'm getting new pads...
jelanier
Sep 4, 2011 03:39 AM
wantonetoo
May 4, 2005 10:07 AM
MaxGeek
Jan 13, 2005 07:01 PM
124Spider
Sep 7, 2004 07:25 PM
frankyknuckles
Jul 1, 2003 03:07 PM
