What kind of power are you forced induction guys running?
I think the power curve of the turbo is THE reason to go with a turbo (any maybe the sound lol). I think a SC has a more on/off response than a turbo as the SC is always spooled ready to go..
As far as throttle response/power band, I have something I'm working on that may help lower top end power and raise mid range even further! It may be a while before its completed but I've been emailing with a new tuner that thinks its possible.
I'll probably lighten car further still target around 8:1 but with much higher mid range.
If you want ridiculously fast spool/throttle response, try the EFR 7163. It's a tiny turbo that seems to have a compressor map very similar to the GT3076R. It also has an aluminum bearing housing. The dyno tests of it show it spooling faster than the stock STI and Evo turbos, but able to make over 500 whp on E85...
Tim
Tim
I'm at 450hp at the moment running a custom manifold with a hta3076 turbo. 1.1 bar of boost. Going to 1.4-1.5 bar soon once I have finished testing the cams for urge designs. Don't have any issues with heat but done a lot of work to prevent any issues.
-Marc
circuitclub
03-20-2009 08:39 PM
