wheel studs, arp vs msi
Old 05-10-2019, 03:53 AM
summitrider2012's Avatar
Default wheel studs, arp vs msi
found a couple of threads about both options but it seems the arp is a love hate thing while the msi seem like a more reliable option. do you need to get the lug nuts they sell or will any open nut with the correct angle for the rim work (obviously the threads are the same but will it make it stronger and more reliable)? can you get them with the NASCAR cut and install them with out removing the hub and bearing? opinions on both or other options? thanks!
Old 05-10-2019, 05:28 AM
Ricky_Flowers_'s Avatar
How is the ARP stud a love/hate thing? I have OE length ARP studs on my car and they've given me no issues. I installed them while I replaced the bearings and hubs at all four corners, so it was easy for me. Don't think you can install MSI or ARP studs with the hub attached to the knuckle.
Old 05-10-2019, 06:29 AM
flanders's Avatar
You can do it without removing hub and bearing, but you will need to grind out a fair bit of material on the knuckle for it to be possible.
Also the shoulder on the stud needs to be grinded flat on one side.
Got some pictures in my build thread https://www.s2ki.com/forums/automoti.../#post24595584
As long as the threads remains the same any open end nut should work.
Old 05-10-2019, 06:54 AM
it seems half the people have been fine with them while the other half had had them fail on them.
Old 05-10-2019, 06:56 AM
where did you get the brake duct adapters for the backing plates?
Old 05-10-2019, 07:13 AM
flanders's Avatar
Can't remember but from some UK dealer, I have the 51mm ones https://www.revotec.com/acatalog/Air-Outlet-Ducts.html
Old 05-10-2019, 08:34 AM
thanks, i was thinking of installing that part while i have the hubs apart if i go that route. or i may just cut the backing plate and replace the screws with bolts so it can be taken off at a later date.
Old 05-11-2019, 07:21 AM
eastcoastbumps's Avatar
I've used both extensively and much prefer the MSI. Both will be very reliable however.
The MSI's have a longer bullet nose and are specifically designed to be hit with their spring loaded pit socket for changing wheels during a race. We have never cross threaded an MSI or broken one. You can cross a ARP if you really screw up the alignment because of the shorter bullet nose.
For HPDE stuff both brands work fine. For racing the MSI stud is cut perfectly against the nut so it spins on quicker than a stock unit and it stays on. Basically just loose enough to spin on quick, without being so loose that the lug nut backs off during the race. Curtis at MSI told me years ago that he lost business to another supplier that was cutting the nut more so it would spin on easier. Then the teams started loosing wheels part way through the stint. The nut would work loose. There's a lot that goes into his work. A new MSI stud and nut spin on like absolute butter before they get dirty.
We had to take left side tires twice last weekend at Road America during an 8hr enduro and I never thought twice about how it would go. It just works.
-Paddy
freq (05-12-2019)
Old 05-12-2019, 05:54 AM
freq's Avatar
I'm still on stock studs but all I have ever heard was RAVE reviews on MSI.
Old 05-13-2019, 01:50 PM
-Paddy
what is good practice for the wheel studs? I have always torqued the wheels then drive it so everything heats up then torque them again hot and then leave them alone until you take the lugs off again. I use 90 ft lbs.
Quick Reply: wheel studs, arp vs msi
